FS Gas Tank 1970-1974 Very Clean $150 Bare tank, $250 Complete, Early Style Tank that uses a steel expansion tank |
bdstone914 |
May 7 2016, 03:00 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I pulled this tank from a 914 in a Pick a Part yard. It is a very clean tank with little surface rust and most of the original paint and white stamp markings intact.
I wiped down the outside and sprayed the inside with carb cleaner to remove most of the varnish that formed when the tank sat in the California sun with the last dap of gas in it. I have a set of cleaned nipples and nuts and will include them with new paper gaskets and a new screen. I can also supply a filler neck, expansion tank, fuel sender and or assemble it all with new gaskets. $150 Bare tank, $250 Complete. Prefer local pick up but will ship from 92505 CA Attached thumbnail(s) |
flmont |
May 8 2016, 09:54 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Ill take that tank,..if it fits a 76' and if its that clean thru-out the whole tank,.??
Thanks Frank |
Lo-Fi Version | Time is now: 1st June 2024 - 04:55 AM |
