breather catch tank, blowing or sucking, I don't know |
machina |
Oct 6 2004, 04:57 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Planning on mounting this catch can remotely, does the pressure from the motor blow or suck?
I don't know if the filter on the tank is to keep vapor out of the motor bay or to keep from sucking dirt into the breather lines. I only need to run lines from each head, the oil fill tower, and then to the tank. Attached image(s) |
machina |
Oct 6 2004, 07:25 PM
QUOTE(Brad Roberts @ Oct 6 2004, 08:56 PM) You wont be happy with that setup. Oil escapes OUT of that type of filter then it leaves a fine mist in the engine compartment that dirt will stick too. I semi know where you are headed with this race car... build/buy a large breather box for the trunk and run ALL your lines into it with a K+N setup. This way it only oils the trunk which is easier to clean than the engine compartment. The back trunk is exactly where I am mounting the tank. So your reccomending a larger catch tank with a K&N? Isn't that kind of what I got? |
Lo-Fi Version | Time is now: 1st June 2024 - 04:24 AM |
