No Crank Issue |
No Crank Issue |
orbit398 |
May 14 2016, 01:39 PM
Member Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
Not sure what to check an looking for pointers.
Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. |
worn |
May 15 2016, 10:37 AM
can't remember Group: Members Posts: 3,175 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Not sure what to check an looking for pointers. Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. Did the engine warm up? It would seem that Otto, or whomever at Bosch, signed off on the solenoid design sheet without testing them hot. In some cases the solenoid will draw juice but freeze and not move. You don't even get a click. Ask me how I know 1,000 miles from home. |
Lo-Fi Version | Time is now: 17th June 2024 - 12:44 PM |
