orbit398 |
Member ![]() ![]() Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region ![]() |
Not sure what to check an looking for pointers.
Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Not sure what to check an looking for pointers. Ran fine this morning in garage, every thing worked. I had the fuse panel unmounted as I finished installing the DPD under dash blower and tied into a wire position that comes on once the key is on. Put it all back together and now it doesn't crank. Weird. Battery has a charge. Just wondering what the culprit might be. Chances are something you touched is making an intermittent connection. Check all the wires you touched. Keep in mind that spade connectors on the fuse panel actually touch a very tiny bit of the spade and oxidation can wreak havoc on dependable operation. Clean any spades you touched. Also clean the fuse connections. They can oxidize very easily and if bumped, can cause intermittent contact. |
Lo-Fi Version | Time is now: 17th June 2024 - 12:06 PM |
