1972 914 |
1972 914 |
Zimmy |
May 15 2016, 07:00 PM
I'm new here ... Group: Members Posts: 0 Joined: 31-July 14 From: Canada Member No.: 17,712 Region Association: None |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500
michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:26 AM |
