Zimmy
May 15 2016, 07:00 PM
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500
michael_zimmerman5@sympatico.ca
- rebuilt engine bottom end including new bearings for rods, crankshaft, and cam
- drilled and pipe plugged oil galleries
- new oil seals
- thermostat cable
- cylinders, pistons and rings 96mm (1910cc)
-proper compression ratio calculated and barrel shims installed
-cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves)
- elephant feet valve adjusters
-all sheet metal media blasted and re-paint
-dual 40mm HPMX carb kit
-ignition wires, cap,rotor and plugs
- 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter
-end play on crankshaft and flywheel set to spec
-flywheel and clutch assembly inspected,cleaned and reinstalled
-transmission overhauled with new seal/gasket kit -this is a side shift 5 speed
-1st and 2nd gear syncros replaced
-installed good used 1st reverse slider
-new synthetic oil
-new braided ground strap
-drive shafts and cv joints cleaned and inspected
-4 new cv joint boots and grease kits/clamps
-all new shifter bushings and boots
-gas tank removed/cleaned and painted with 2 stage paint
-new fuel lines and proper german clamps
- new fuel pump and filter
-cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat
-sourced master cylinder/steering rack under tray from USA and paint, install with new hardware
- ATS rims blasted and repainted in 2 stage silver/clear
-new tires
-front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated
-front and rear caliper rebuild kits with e-brake kits
-e-brake cables and pins
-front and rear brake pads
-turned and painted brake rotors, rotor hats painted in 2 stage paint
-repacked front bearings with new grease seals
-all new rigid brake lines including center tunnel line with fittings
-new master cylinder with rubber connector lines
-braided front and rear brake hoses
-media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance
-new alternator and belt
-new stater motor
-new battery
-newer radio with cd player
-drive car and shake down, adjust and make sure everything works mechanically.
nwm5709
May 17 2016, 08:26 AM
Where is the car located?
Zimmy
May 17 2016, 08:41 AM
QUOTE(nwm5709 @ May 17 2016, 06:26 AM)
Guelph, Ontario, Canada.
Pat Garvey
May 24 2016, 06:43 PM
QUOTE(Zimmy @ May 15 2016, 07:00 PM)
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here?
Zimmy
May 25 2016, 10:05 AM
We've established the following guidelines to help make your sales/purchases as successful as possible!
- Please put a price in your ad and state how you would like payment.
Sorry I forgot how I wanted the payment transaction. I would like cash or certified bank draft.
Series9
May 31 2016, 08:59 AM
Pat Garvey,
Rules are rules:
Do not comment on people's ads unless you are interested in purchasing the item or vehicle and you are requesting further information from the seller.
If you have personal issues with a seller, keep them as such... personal.
If you think the ad is misleading, contact the seller and an Admin via private message.
Any further abuse or violations of the site rules (name calling) will get you banned.
Zimmy
Jun 28 2016, 07:56 AM
Posted pictures to my facebook page.
https://www.facebook.com/media/set/?set=a.1...mp;l=9a45723307QUOTE(Zimmy @ May 15 2016, 05:00 PM)
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
Jun 28 2016, 08:03 AM
QUOTE(Pat Garvey @ May 24 2016, 08:43 PM)
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
Pat - looks like he followed all the rules. Pics and vin are not required to sell a car. I would add pics it does help sell. Pat, you should know better and give the guy a break.
0396
Jun 28 2016, 08:20 AM
QUOTE(Pat Garvey @ May 24 2016, 05:43 PM)
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
Here's the rules / guidelines for your reference:
Rules!, Return to the forum
rwilner
Jun 28 2016, 07:32 PM
For anyone willing to follow that facebook link, there are tons of pics there...over 100.
Looks like an engine rebuild (carbs tho), completely restored brake calipers, refinished fuel tank. There's a riveted patch in the floor but I don't see much rust.
Worth checking out if you're local and in the market. (I'm the latter, not the former)
Larmo63
Jul 1 2016, 12:57 AM
Looks like a pretty good car for the money.
He did a lot of work on it.
rick 918-S
Jul 8 2016, 05:28 PM
QUOTE(rwilner @ Jun 28 2016, 08:32 PM)
I hate face book. I can only see about 24 of the photos and there's a stupid sign up banner blocking the page like it's some big harry secret.
Zimmy
Jul 18 2016, 07:38 PM
Price update $8000.00 OBO
quote name='Zimmy' date='May 15 2016, 05:00 PM' post='2345154']
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
[/quote]
Zimmy
- new oil seals
- thermostat cable
-new synthetic oil
-new tires
-new stater motor
-new battery
[/quote]
doherty224
Jul 19 2016, 11:43 AM
Very nice looking, looks like a more than fair price to me. GLWS!
Zimmy
Apr 12 2017, 06:48 PM
Hello,
Car is still for sale. This car need to be enjoyed by someone.
Thanks for looking.
Mike.
