| p914 |
Sep 16 2004, 01:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
I have the DJet system on my 75 2.0.
When the engine is all warmed up, and i come to a stop and the engine drops to idle, it sputters and chokes. Then if it continues to run it will slowly ramp back up to proper idle. Sounds like it just drops down to idle too fast for the old DJet. The engine runs like a top except for when it is warmed up and that little idle problem kicks in. Is there anything that can slow down the revs so it doesn;t just drop down to idle other than using the gas pedal? I took off all the air pump stuf years ago, so that system is not there anymore. |
| Rhodes71/914 |
Oct 7 2004, 11:53 AM
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
QUOTE(p914 @ Oct 7 2004, 09:43 AM) It needed a valve adjustment. Didn't put more than 3-4K miles on it since the last adjustment. Cured the die out problem. Thanks for the input guys. Looks like you were right on time for that valve adj. |
p914 Drops to idle fast and then chokes Sep 16 2004, 01:45 PM
2-OH! I have the same problem...Been asking, but no one ... Sep 17 2004, 07:39 AM
michelko hi,
try this link http://members.rennlist.com/pban... Sep 17 2004, 07:45 AM
2-OH! Thanks michelko, I'll give it a try...
2-OH... Sep 17 2004, 07:50 AM
RustyWa Won't it do that if the car is lean? Maybe tr... Sep 17 2004, 08:10 AM
tod914 Maybe test your head temp. sensor??? Sep 17 2004, 08:34 AM
p914 Mine doesn't hunt as the mixture is good. It w... Sep 17 2004, 08:36 AM
2-OH! Tod:
New head sensor...Put one in during the engi... Sep 17 2004, 11:17 AM
p914 Along with the ecu adj. you may need to adjust th... Sep 17 2004, 12:48 PM
p914 It needed a valve adjustment. Didn't put more... Oct 7 2004, 11:43 AM
Rhodes71/914
p914 Seems like adjustments would last up to 6k miles..... Oct 7 2004, 12:14 PM
Rhodes71/914
p914 I think the decel valve was taken out a year or so... Oct 7 2004, 03:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 08:07 PM |
