VW clutch disc and pressure plate, Same? |
Shindog1961 |
May 22 2016, 08:47 AM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
I'm looking for a new disc and pressure plate. Are the 215mm VW parts the same? They look awfully similar and are a fraction of the price.
porschetub |
May 22 2016, 01:51 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'm looking for a new disc and pressure plate. Are the 215mm VW parts the same? They look awfully similar and are a fraction of the price. From memory I would say yes and no,the disc is the same but the pressure plate has different offset. The disks were made with 4 and 6 springs but I think now they are mostly the 6 supplied by many resellers. Inspect the pressure plate carefully if the condition is ok you can reuse them,also make sure your flywheel still has a reasonable running surface. Shop around for your parts prices seem to vary a fair amount,good luck. |
Shindog1961 |
May 22 2016, 03:49 PM
I'm looking for a new disc and pressure plate. Are the 215mm VW parts the same? They look awfully similar and are a fraction of the price. From memory I would say yes and no,the disc is the same but the pressure plate has different offset. The disks were made with 4 and 6 springs but I think now they are mostly the 6 supplied by many resellers. Inspect the pressure plate carefully if the condition is ok you can reuse them,also make sure your flywheel still has a reasonable running surface. Shop around for your parts prices seem to vary a fair amount,good luck. What should I look for on the pressure plate? I do have one from another 914. Flywheel has been refurbished. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:27 AM |
