How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
6freak |
May 24 2016, 06:55 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I also posted this on pp however I usually get better responses here. I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? Oil console on the tank is not right |
6freak |
May 24 2016, 07:03 AM
I also posted this on pp however I usually get better responses here. I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? Oil console on the tank is not right damn triple reply off the first cell phone post .....i think its the oil console on the tank is 180 out ,,like turn it over...good luck MikeC |
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 PM |
