How to verify crankcase oil level on a /6? |
tornik550 |
May 23 2016, 08:52 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I also posted this on pp however I usually get better responses here.
I recently rebuilt my 2.7l. I have the engine on a test stand. The oil tank is mounted at approximately the same level as it would be in the car. I am questioning the actual oil level in my crankcase. I put 12qts in the tank. I cranked the engine without ignition to get the oil pressure up. The dipstick doesn't show any oil so I put a couple more quarts in and it still doesn't show on the dipstick. I suspect there is actually too much oil because I can see a little bit of standing oil in the cylinders with a scope. It is not oil from assembly cause it was a different color. I am using a used 911 oil tank from an unknown engine. Normally I would just wonder if my dipstick was just not correct however since the setup is on a test stand, I wonder if something else is going on and I would like to verify the oil level in the case before starting the engine. How can I do that? |
ConeDodger |
May 24 2016, 05:58 PM
Apex killer! Group: Members Posts: 23,594 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
WCR participants got to see first hand what happens when you overfill. I paid my daughter's friend to prep the car for the trip to Medford. When I returned on Sunday, I asked him, "did you check the oil?" He said, "yes, it was two quarts low." (IMG:style_emoticons/default/sad.gif)
Pretty much every time I hit the gas hard, I blew a cloud of thick oil smoke. (IMG:style_emoticons/default/blink.gif) I haven't told Carlo yet. He's kind of sensitive... (IMG:style_emoticons/default/cheer.gif) |
r_towle |
May 24 2016, 06:14 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
WCR participants got to see first hand what happens when you overfill. I paid my daughter's friend to prep the car for the trip to Medford. When I returned on Sunday, I asked him, "did you check the oil?" He said, "yes, it was two quarts low." (IMG:style_emoticons/default/sad.gif) Pretty much every time I hit the gas hard, I blew a cloud of thick oil smoke. (IMG:style_emoticons/default/blink.gif) I haven't told Carlo yet. He's kind of sensitive... (IMG:style_emoticons/default/cheer.gif) Carlo needs to learn. (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 01:32 PM |
