> Old school builds/Tried, true, tested....cheap trick, Common sense builds and ideas/ solutions for the "common man"
Gunn1
post May 25 2016, 09:06 PM
Much like my grandmothers recipe for Amish oatmeal chocolate chip cookies would have been lost forever if someone didn't take the time to write it down, it is similar that many of those on the site who comment or watch from a far have common sense low cost solutions to building a type 4.
Not really asking for your trade secrets or any self promotion, just common sense solutions that over the years have worked for you.
Primarily want to hear folks low tech, low cost alternatives for repairing or rebuilding the type 4 or the 914.
Anything as a permanent approved repair fix to a Macgyver fix that can get you by.
Anything that works well in combination that you figured out on your own or with someone else's help.
Again primarily looking for a dialog on low cost common sense technicis to type 4 repair and rebuild info.
Cheap tricks.
Thank you
Jake Raby
post May 26 2016, 12:48 PM
Engine Surgeon
Carbureted or EFI? Which carbs?
Gunn1
post May 26 2016, 03:12 PM
QUOTE(Jake Raby @ May 26 2016, 01:48 PM) *
It can be related to either or any fuel delivery type system.
The only few criteria are....subjects are internal combustion and or 914 body style related
Got to be cheap fix, or outside the box fix(MacGyver) or unorthodox repair, rebuild hints.
Emphasis on cheap tricks and common man relatable.
OU812   Old school builds/Tried, true, tested....cheap trick   May 25 2016, 09:06 PM
SirAndy   Anything as a permanent approved repair fix to a M...   May 25 2016, 09:15 PM
SirAndy   Old trick from my dirt bike racing days: If you b...   May 25 2016, 09:18 PM
r_towle   Old trick from my dirt bike racing days: If you ...   May 25 2016, 09:59 PM
OU812   [quote name='SirAndy' post='2350539' date='May 25...   May 25 2016, 10:18 PM
rick 918-S   [quote name='OU812' post='2350536' date='May 25 2...   May 27 2016, 01:44 PM
thelogo   I ll jump in here :beer3: If you need a motor ,...   May 25 2016, 09:19 PM
DBCooper   Much like my grandmothers recipe for Amish oatmea...   May 25 2016, 09:29 PM
OU812   Much like my grandmothers recipe for Amish oatme...   May 25 2016, 09:54 PM
914bub   The coveted Amish Oatmeal cookie recipe please.......   May 25 2016, 10:03 PM
OU812   The coveted Amish Oatmeal cookie recipe please......   May 25 2016, 10:15 PM
TJB/914   The coveted Amish Oatmeal cookie recipe please......   May 27 2016, 10:57 AM
914_teener   The coveted Amish Oatmeal cookie recipe please.....   May 27 2016, 12:48 PM
r_towle   [quote name='TJB/914' post='2351173' date='May 27...   May 27 2016, 02:32 PM
OU812   [quote name='TJB/914' post='2351173' date='May 27...   May 27 2016, 07:34 PM
OU812   The coveted Amish Oatmeal cookie recipe please.....   May 27 2016, 08:05 PM
Mueller   Much like my grandmothers recipe for Amish oatmea...   May 25 2016, 10:37 PM
mepstein   * This is really the way to save big bucks on a ca...   May 26 2016, 05:43 AM
bandjoey   It fixes everything :welder:   May 25 2016, 10:58 PM
rick 918-S   The bottom end of a type IV is nearly indestructib...   May 26 2016, 06:41 AM
OU812   The bottom end of a type IV is nearly indestructi...   May 26 2016, 08:45 AM
RobW   Buy a known engine from a known person. The sum of...   May 26 2016, 07:59 AM
Brian Mifsud   Rebuild only when MORE exhaust exits crankcase ven...   May 26 2016, 11:55 AM
Rand   Oh man, you're killing me, Andy. Needed this. ...   May 26 2016, 12:04 PM
SirAndy   Oh man, you're killing me, Andy. Needed this. ...   May 26 2016, 12:23 PM
Jake Raby   Carbureted or EFI? Which carbs?   May 26 2016, 12:48 PM
OU812   Carbureted or EFI? Which carbs? It can be relat...   May 26 2016, 03:12 PM
r_towle   When you break the accelerator cable, tie off the...   May 26 2016, 06:27 PM
Kansas 914   When you break the accelerator cable, tie off th...   May 26 2016, 08:17 PM
OU812   When you break the accelerator cable, tie off t...   May 27 2016, 03:55 AM
r_towle   When you break the accelerator cable, tie off t...   May 27 2016, 10:49 AM
arkitect   [quote name='Kansas 914' post='2350940' date='May...   May 28 2016, 04:46 AM
OU812   [quote name='Kansas 914' post='2350940' date='Ma...   May 28 2016, 06:56 AM
OU812   Here is her Oatmeal Cookie Recipe, they are also g...   May 27 2016, 07:50 PM
Philip W.   Here is her Oatmeal Cookie Recipe, they are also ...   May 28 2016, 09:02 AM
OU812   Here is her Oatmeal Cookie Recipe, they are also...   May 28 2016, 10:00 AM
914_teener   Jake posted it already. FI or carbs. Thank for t...   May 27 2016, 09:33 PM
OU812   Jake posted it already. FI or carbs. Thank for ...   May 28 2016, 03:43 AM
rhodyguy   In a pinch and the proper hex socket is at home in...   May 28 2016, 08:52 AM
- Lo-Fi Version Time is now: 16th June 2024 - 08:33 PM
