Oh dear-here we go again!, Running rich |
porschefile2010 |
May 26 2016, 07:49 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
I needed your help before and now we have a new issue. I have just about had it with the ongoing problems.
Mine is a 75, 2.0 with original FI. I dropped a valve seat and gave it to my garage to repair the head and replace all the valves. It all went back together and fired and ran but only for a very short time as all the cylinders ran rich and fouled the plugs. So my take on this is that it can't be the injectors as they are not all likely to fail at the same time. Perhaps it is something in the system that makes the injectors fire continuously? So could that be trigger points? If you could give me any ideas as to why all the plugs might foul I will start looking at each one until I nail it. Thanks Guys. Richard (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
Tbrown4x4 |
May 27 2016, 08:59 AM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Sounds like when your valve seat dropped it may have blown too much back pressure through the intake and took out the MPS. See if the MPS holds a vacuum.... Hmmm. There's a thought. I have a spare MPS so I could change that out and see what happens. Thanks Just put a hose on it and see if it holds vacuum. If the diaphragm is blown, the ECM thinks the engine is under full load and goes rich. |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:10 AM |
