Yikes! Need Guidance !, Spring Washer on Rocker Shaft Broken ! |
Beebo Kanelle |
May 29 2016, 05:44 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
My engine developed a tapping noise so, I pulled the valve covers to check the clearances.
I was greeted with items shown in photo 'Big Problem 01'. It turns out that the spring washer that controls the rocker arm geometry has failed and the rocker arm has moved as shown in 'Big Problem 02'. My temporary solution is to remove the rocker arm assembly and replace the spring washers. Are There any problems with this solution? Does anybody have the specs for these springs washers? Thanks in advance. |
Beebo Kanelle |
May 30 2016, 09:33 AM
Thank you !
I'm on it today. I'll let you know how it turns out. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:11 PM |
