Ignition switch?, lazy starter |
JimN73 |
May 31 2016, 06:32 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Sometimes, fairly often, the starter motor turns over slowly and may (or may not) speed up after a second or so. The engine starts. 30 seconds later, it may fire right up.
Doesn't seem to matter if the engine is warm or cold. The starter has one of McMarks magical relays. I've checked the grounds and the wiring - all is tight. So the ignition switch seems to be the last optin. Anyone seen this before? thanks, |
BeatNavy |
May 31 2016, 07:51 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Just my experience for reference: I replaced my ignition switch about 18 months ago with the cheap replacement. Within a few months I could "feel" that it was harder to start. Specifically, I had to turn the key a certain way, and it was exhibiting symptoms similar to what you describe. Then I installed a hot start relay like you have (I believe) about 6 months ago hoping it would prevent total switch failure. Two weeks ago, however, the switch crapped out. I don't know if the damage had already been done before I installed the relay, but even with the relay the switch failed.
The good news is that a cheap replacement is less than $10 and it now takes me only about 30 minutes of time to install. So it may still be worth the effort to purchase and install a new ignition switch if you have doubts. It may otherwise leave you stranded at some point. I think a hot start relay helps but doesn't necessarily prevent ignition switch failure. Again, just my experience. |
Lo-Fi Version | Time is now: 12th June 2024 - 07:17 PM |
