Ignition switch?, lazy starter |
JimN73 |
May 31 2016, 06:32 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
Sometimes, fairly often, the starter motor turns over slowly and may (or may not) speed up after a second or so. The engine starts. 30 seconds later, it may fire right up.
Doesn't seem to matter if the engine is warm or cold. The starter has one of McMarks magical relays. I've checked the grounds and the wiring - all is tight. So the ignition switch seems to be the last optin. Anyone seen this before? thanks, |
jcd914 |
Jun 1 2016, 12:29 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If the issue is the speed (RPM) the starter turns the engine over at, then you can rule out the ignition switch and hot start relay. The ignition switch and /or hot start relay only control the engagement voltage to the started solenoid. So if the starter turns over the ignition switch has done it's job.
It has no impact on the speed at which the started turns. The current to drive the starter motor flows through the solenoid. The speed the starter turns at is dependent on the ability of voltage and amperage to flow through the starter. How much voltage and amperage is required depends on how much work the starter is trying to do. So something is limiting the voltage and/or amperage or the starter is having to do more work than normal. Have you disconnected the battery cables and cleaned the connections? Have you disconnected and cleaned the ground connections? What is the condition of the battery? Does the starter make abnormal noise? grinding, rumbling? The starter bolted tightly in place? Jim |
barefoot |
Jun 1 2016, 09:05 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
If the issue is the speed (RPM) the starter turns the engine over at, then you can rule out the ignition switch and hot start relay. The ignition switch and /or hot start relay only control the engagement voltage to the started solenoid. So if the starter turns over the ignition switch has done it's job. It has no impact on the speed at which the started turns. The current to drive the starter motor flows through the solenoid. The speed the starter turns at is dependent on the ability of voltage and amperage to flow through the starter. How much voltage and amperage is required depends on how much work the starter is trying to do. So something is limiting the voltage and/or amperage or the starter is having to do more work than normal. Have you disconnected the battery cables and cleaned the connections? Have you disconnected and cleaned the ground connections? What is the condition of the battery? Does the starter make abnormal noise? grinding, rumbling? The starter bolted tightly in place? Jim I just had a very similar problem, light load electrical stuff worked OK, but starter would not run at all. It was a poor ground connection at the battery terminal. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:05 PM |
