| Mikey914 |
Jun 2 2016, 01:58 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,778 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Just a feeler for making the hoses that many are cracked and broken, I know I have take 2 cars worth to make one good setup.
So obviously price is an issue, but assuming a reasonable price who could use a set? ($25 ish) If there's enough interest I will pursue these. |
| Darren C |
Jun 2 2016, 02:25 AM
Member ![]() ![]() Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
Mark,
Check out a product called Copex, and my build thread. They do a perfect match on size and appearance to the Porsche drain hose. It's much tougher than the original, thicker walled, very flexible and durable. (The PVC version without internal wire, they do different types the soft thin wall is too easy to crush or kink/fold, I found the PVC slightly rubbery version works best and is fully smooth on the inside so water runs through without being held in the helix) Plus if you buy a 30m roll it works out about $1.50 a metre, so the cost per set for car airbox in the trunk would be around $3, or $5 if you included the drain hoses in the engine bay. (IMG:http://www.914world.com/bbs2/uploads_offsite/i265.photobucket.com-18255-1464856385.1.jpg) |
Mikey914 Possible GB - Airbox drain hoses Who needs a set? Jun 2 2016, 01:58 AM
Mikey914 Thanks, There is a product at Home Depot that work... Jun 2 2016, 03:08 AM
bdstone914 The 1" irrigation tubing is availabile at Low... Jun 2 2016, 08:09 AM
tnsmike I would take 3 sets Jun 2 2016, 04:27 PM
tnsmike I have two friends that want them as well so you c... Jun 2 2016, 04:40 PM
Kansas 914
I have two friends that want them as well so you ... Jun 2 2016, 05:47 PM
Mikey914 Yes, These would be longer so that they can be use... Jun 2 2016, 10:55 PM
Mikey914 Not enough demand to make these but did source a b... Jun 16 2016, 01:48 AM
Mikey914 rain tray drain tubes Jun 16 2016, 01:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 07:03 AM |
