Made it to Calif......Then Gremlins, Won't start |
Coondog |
Jun 2 2016, 10:27 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
I did prey to make it home safe, just didn't add the part to keep it running.
Drove great 6 hrs straight then ??? Here are the symptoms. Every once in a while I felt a very slight surge . Like as fast as a blink of the eye but it got my attention. Sometimes volt meter would just stay on 12 then move towards 12.5 Tach bounced every once in a while, but it's always done that. Got off freeway and stalled. Had to keep revs up at every red light as it would not hold idle. Parked in front of house. Turns over but does not start. No putt putt no nothing. 1975 1.8 fuel inject. All stock. Fuel pump ? Coil ? Could be its pissed off cause I took it out of Arz !! |
Coondog |
Jun 2 2016, 01:37 PM
I have read that your suspose to hear the fuel pump running ?? I have never heard anything running under the front trunk.
SLITS |
Jun 2 2016, 01:44 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I have read that your suspose to hear the fuel pump running ?? I have never heard anything running under the front trunk. DJet ... fuel pump runs for a couple of seconds when the key is turned on. Won't run again until you turn the starter LJet ... fuel pump runs with the turn of the starter as I remember. Check your points / condenser. |
Lo-Fi Version | Time is now: 12th June 2024 - 12:03 AM |
