2.0 engine SOLD, 2,9 engine for sale |
westtexass2k |
Jun 2 2016, 08:11 PM
Newbie Group: Members Posts: 40 Joined: 31-December 11 From: San Angelo Tx Member No.: 13,954 Region Association: None |
I just purchased a 74 model with 2.0 motor. The car had been sitting for 12 years since last driven. I purchased the car and drug it home. I installed new fuel pump sucked all the old gas out and flushed the lines. Cranked it over a few seconds and it fired right up. No noticable smoke from the exhaust but it has several exhaust leaks and a bad drivers side heat exchanger. They are rusted but sounds like a broken tube in the manifold. Drove it around a few miles. The fuel iinjection had been removed at some point. It looks like its in a box in the trunk. The car currently has a dueal carb set up. I am doing an engine swap and wont be needing this engine. I will be retaining the clutch so it will b be complete engine. It does have a few oil leaks of course. Im asking 750.00 plus shipping im in Texas. Then engine is still in the car. I can send you a video of it running. 325-65o7049
Ok a little confusion on this engine. I has 2.0 head for sure with 3 bolt intake manifolds and angled plugs. It has dual single barrel webers NOT IDF or DeLL. But the engine block is marked with W4 on top. According to the info I have found the W is a 1.7 so since I don't know the history on the car I am not sure whats been done. All I know it starts and runs pretty good. I have not cleaned the carbs or checked timing or anything but it starts good. revs up well and doesn't smoke. Car is definitely a 74 checked the vin and they only came with 1.8 and 2.0 engines. The lady I purchased it from says that the engine hasn't left the car the 15 years she owned it and the previous owner never mentioned that engine has been changed. |
Lo-Fi Version | Time is now: 6th June 2024 - 02:13 PM |
