| ThePaintedMan |
Jun 1 2016, 10:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
$209 for the pair? Sounds too good to be true. Anyone have any experience with these?
http://www.thesamba.com/vw/classifieds/detail.php?id=1934155 (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-13527-1464841158.1.jpg) |
| JamesM |
Jun 2 2016, 01:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
$209 for the pair? Sounds too good to be true. Anyone have any experience with these? http://www.thesamba.com/vw/classifieds/detail.php?id=1934155 (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-13527-1464841158.1.jpg) Amazon has a few vendors that sell LED headlights that appear identical to the GE Nighthawks (which themselves are identical to the Trucklite LEDs") for ~140 a pair. I haven't personally tried the nighthawks due to the price, but the sets I got for $140 were worth it. I have them installed on my Vanagon and 2 of my 914s. They make a HUGE difference for night driving and are a "safe" plug and play upgrade as they have less current draw than even stock headlights (something like only 3amp) Side by side output with LED on the left and stock highbeam on the right. The white light on the far right is actually coming from the LED headlight on the left. One of these casts way more light than a pair of stock bulbs. They made an even lager difference on the 914s, due to the old wiring/voltage drop, the LEDs are pretty much un affected by it. The vans stock headlights were not bad whereas the 914s were near useless. |
| JamesM |
Jun 2 2016, 01:32 PM
Bolt on, nothing else needed
http://www.amazon.com/YITAMOTOR-Round-Head...ailpage_o02_s00 or http://www.amazon.com/WHDZ-Headlight-Wrang...ailpage_o00_s00 They are listed as different brands but are the exact same light, there are a few others for sale that are exactly the same as well. Whats really odd about them, looking at them head on they appear to be much dimmer, but man they REALLY light up the road, especially reflective signs. |
| 87m491 |
Jun 3 2016, 11:12 AM
Member ![]() ![]() Group: Members Posts: 331 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States
Could be the picture angles, but those lenses look perfectly flat with no fluting to direct the light. relying instead on the reflector. That IME is a pretty poor design and will have oncoming cars flipping you off. Go with a stock or better lamp....
Bolt on, nothing else needed http://www.amazon.com/YITAMOTOR-Round-Head...ailpage_o02_s00 or http://www.amazon.com/WHDZ-Headlight-Wrang...ailpage_o00_s00 They are listed as different brands but are the exact same light, there are a few others for sale that are exactly the same as well. Whats really odd about them, looking at them head on they appear to be much dimmer, but man they REALLY light up the road, especially reflective signs. |
| thomas@vintagecarleds.com |
Jun 3 2016, 11:21 AM
Newbie ![]() Group: Members Posts: 36 Joined: 3-June 16 From: Houston Member No.: 20,065 Region Association: None |
Could be the picture angles, but those lenses look perfectly flat with no fluting to direct the light. relying instead on the reflector. That IME is a pretty poor design and will have oncoming cars flipping you off. Go with a stock or better lamp.... Photo of our lens below, its a DOT approved lens with fluting that directs the beam pattern. It out preforms a stock lamp, I test each unit by hand before shipping. Honestly, ive tested 20 different styles of glass 7" headlamps and this is the one that gave a SAFE and quality beam pattern. Try them out, if you are not happy with them we have a 100% refund (no re-stocking fees) I have yet to have a return. Yes.. I took the photo upside down (IMG:style_emoticons/default/rolleyes.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-20065-1464974467.1.jpg) |
| 87m491 |
Jun 3 2016, 01:16 PM
Yes I see the design, by "flat" I was replying to the poster of the Amazon units. I'm guessing another of your lamp benefits would be that they are probably shallower to accommodate the excess bulb depth out the back of the housing while still fitting in most applications? I know I might have interference issues in some apps but plenty of room in others. I'm thinking flip up apps like 914/944 might be tight with stock "E" code lamps.
s Could be the picture angles, but those lenses look perfectly flat with no fluting to direct the light. relying instead on the reflector. That IME is a pretty poor design and will have oncoming cars flipping you off. Go with a stock or better lamp.... Photo of our lens below, its a DOT approved lens with fluting that directs the beam pattern. It out preforms a stock lamp, I test each unit by hand before shipping. Honestly, ive tested 20 different styles of glass 7" headlamps and this is the one that gave a SAFE and quality beam pattern. Try them out, if you are not happy with them we have a 100% refund (no re-stocking fees) I have yet to have a return. Yes.. I took the photo upside down (IMG:style_emoticons/default/rolleyes.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-20065-1464974467.1.jpg) |
ThePaintedMan Another LED solution Jun 1 2016, 10:18 PM
bandjoey But I don't think it will fit into the tight b... Jun 1 2016, 10:22 PM
Mueller I thought that was a household 110v plug at 1st :) Jun 1 2016, 10:23 PM
eric9144 Wow and a claim of 4000 lumen output! :popco... Jun 1 2016, 10:33 PM
matthepcat Cool. I would need to see a beam pattern before bu... Jun 1 2016, 10:36 PM
ThePaintedMan I have a sneaking suspicion that they might actual... Jun 1 2016, 10:42 PM
RobW Looks promising. Some modification would be requir... Jun 1 2016, 10:42 PM
eric9144 The other model they sell is even cheaper, still a... Jun 1 2016, 10:47 PM
matthepcat
The other model they sell is even cheaper, still ... Jun 1 2016, 11:21 PM
mrholland2
[quote name='eric9144' post='2353442' date='Jun 1... Jun 2 2016, 10:52 AM
eric9144
[quote name='eric9144' post='2353442' date='Jun ... Jun 2 2016, 11:06 AM
bandjoey Is there a law covering how bright the lights can ... Jun 2 2016, 11:39 AM
matthepcat The "ricer lights" you see ...also on li... Jun 2 2016, 12:41 PM
mrholland2
The "ricer lights" you see ...also on l... Jun 3 2016, 05:26 PM
matthepcat Here is a basic overview ( Leaves out some details... Jun 3 2016, 06:49 PM
eric9144 BULB TYPE WATTAGE LUMENS (high/low)
9003/HB2 60/55... Jun 2 2016, 12:02 PM
JamesM
Could be the picture angles, but those lenses loo... Jun 3 2016, 02:01 PM
[quote name='87m491' post='2354173' date='Jun 3 2... Jun 3 2016, 02:07 PM
RobW Nice. Any issues installing on the 914? Jun 2 2016, 01:28 PM
JamesM
No issu... Jun 2 2016, 01:35 PM
No iss... Jun 2 2016, 07:07 PM
Mark Henry I've looked into it....they won't fit on t... Jun 2 2016, 02:02 PM
Mark Henry BTW the average LED headlight bulb will lose about... Jun 2 2016, 02:06 PM
NeunEinVier
BTW the average LED headlight bulb will lose abou... Jun 16 2016, 12:43 PM
Mark Henry
BTW the average LED headlight bulb will lose abo... Jun 16 2016, 12:55 PM
porschetub superbrightled have a kit for the 914,so no fitmen... Jun 2 2016, 02:07 PM
matthepcat Was it just an LED bulb...or a whole housing?
Did... Jun 2 2016, 02:09 PM
eric9144
I've looked into it....they won't fit on ... Jun 2 2016, 02:20 PM
matthepcat If Mark Henry is correct about the housings, I bet... Jun 2 2016, 06:42 PM
thomas@vintagecarleds.com Hi guys, If you have any questions about our produ... Jun 3 2016, 10:30 AM
87m491 I have "E" code lamps on all my old cars... Jun 3 2016, 11:19 AM
I have "E" code lamps on all my old car... Jun 3 2016, 11:23 AM
87m491 Sweet. That's what I'm talking about... Jun 3 2016, 01:29 PM
eric9144 So Thomas, thanks for chiming in, here's my qu... Jun 3 2016, 11:02 AM
So Thomas, thanks for chiming in, here's my q... Jun 3 2016, 11:18 AM
gandalf_025 New member joining just to sell something... Alwa... Jun 3 2016, 11:37 AM
New member joining just to sell something... Alw... Jun 3 2016, 11:41 AM
gandalf_025
New member joining just to sell something... Al... Jun 3 2016, 12:21 PM
Thanks for replying... I respect your honesty..... Jun 3 2016, 12:28 PM
76-914
Thanks for replying... I respect your honesty.... Jun 3 2016, 12:55 PM
[quote name='thomas@vintagecarleds.com' post='235... Jun 3 2016, 01:08 PM
ThePaintedMan Thomas, you're all good. I think most of us we... Jun 3 2016, 12:23 PM
Any chance you'd be willing to send a pair o... Jun 3 2016, 12:30 PM
87m491 Can you expand on the bulbs mentioned? I see the ... Jun 3 2016, 01:26 PM
Can you expand on the bulbs mentioned? I see the... Jun 3 2016, 01:30 PM
Red72
Can you expand on the bulbs mentioned? I see th... Jun 22 2016, 06:21 PM
[quote name='thomas@vintagecarleds.com' post='235... Jun 23 2016, 10:07 AM
Red72
[quote name='thomas@vintagecarleds.com' ... Jun 26 2016, 12:47 PM
Perfect! Your website doesn't appear t... Jun 27 2016, 06:59 AM
eric9144
Can you expand on the bulbs mentioned? I see th... Jun 3 2016, 01:49 PM
thomas@vintagecarleds.com Oh BTW, People ask me if I carry LED brake lights.... Jun 3 2016, 02:23 PM
Wyvern Did anyone here try a product from this vendor? ... Jun 16 2016, 09:12 AM
Mikey914 We saw these bulbs at SEMA, and from what we could... Jun 16 2016, 09:32 AM
eric9144 My set of 2800's arrived, haven't had a ch... Jun 16 2016, 09:43 AM
Mikey914 What we saw was not the the light unit didn't ... Jun 16 2016, 09:45 AM
bandjoey If someone has nothing else to do the alibaba web... Jun 16 2016, 10:20 AM
Mark Henry Thomas have you fitted these into a 914?
The 914 ... Jun 16 2016, 12:57 PM
NeunEinVier Interesting, didn't realize LED technology had... Jun 16 2016, 01:08 PM
Chris914n6 One thing to note is that LEDs don't put out l... Jun 16 2016, 11:46 PM
87m491
One thing to note is that LEDs don't put out ... Jun 23 2016, 11:32 AM
[quote name='Chris914n6' post='2360440' date='Jun... Jun 23 2016, 03:38 PM
eric9144 I should be attempting install this week---Fathers... Jun 23 2016, 11:00 AM
Kansas 914
I'm still very optimistic they'll be plug... Jun 23 2016, 11:04 AM
I should be attempting install this week---Father... Jun 23 2016, 11:28 AM
Chris Pincetich :wttc:
I installed GE nighthawks last Fall and th... Jun 23 2016, 02:57 PM
eric9144 Well I can answer one question--They DO fit. I di... Jun 24 2016, 09:35 AM
if they require re-wiring its a deal breaker, I... Jun 25 2016, 12:59 PM
eric9144 Finally grabbed my keys and went back to the garag... Jun 26 2016, 10:24 PM
cooper951
Finally grabbed my keys and went back to the gara... Jun 27 2016, 05:08 AM
Are these the $159 lights?
Yes, that... Jun 27 2016, 07:00 AM
Kansas 914 Does anyone have a "template" for aiming... Jun 27 2016, 07:05 AM
Does anyone have a "template" for aimin... Jun 27 2016, 07:23 AM
Kansas 914
When you say all your cars do you mean 914's... Jun 27 2016, 07:27 AM
I suppose I could use one of my "regular... Jun 27 2016, 07:31 AM
Kansas 914
A general rule of thumb is all headlights no matt... Jun 27 2016, 07:44 AM
A general rule of thumb is all headlights no mat... Jun 27 2016, 07:49 AM
anderssj
Does anyone have a "template" for aimin... Jun 27 2016, 07:29 AM
Does anyone have a "template" for aimi... Jun 27 2016, 07:32 AM
anderssj
[quote name='anderssj' post='2364525' date='Jun 2... Jun 27 2016, 07:59 AM
IMO Those Cibie H4 lenses are gold. I wouldn... Jun 27 2016, 08:03 AM
Kansas 914
Kind of long, but very complete:
http://www.dan... Jun 27 2016, 07:45 AM
eric9144 Now we just need a drop in replacement for the fog... Jun 27 2016, 09:50 AM
Amphicar770 This evening I installed a set of Optix LED's ... Jul 2 2016, 09:34 PM
This evening I installed a set of Optix LED's... Jul 3 2016, 11:45 AM
This evening I installed a set of Optix LED... Jul 3 2016, 12:08 PM
[quote name='thomas@vintagecarleds.com' post='236... Jul 3 2016, 03:53 PM
Amphicar770
Those work pretty well, I imported some from Chin... Jul 3 2016, 01:13 PM
[quote name='thomas@vintagecarleds.com' post='236... Jul 3 2016, 03:54 PM
Amphicar770
This evening I installed a set of Optix LED's... Jul 22 2016, 09:56 PM
rothaus Here is another option.
http://www.914world.com/b... Jul 4 2016, 05:50 AM
amfab Just bought a pair of Anzos from Autoanything (no ... Jul 22 2016, 10:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:14 PM |
