Rob Watson's ear, R&R right rear suspension ear |
watsonrx13 |
Aug 29 2004, 02:54 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Today I began the process of replacing the right rear suspension ear. I purchased my pieces from Restoration-Design. The pieces included the right engine shelf, suspension ear, battery tray and battery support.
I began by removing the center section of the engine tray. This shows the spot-welds drilled out. I used a 1/4" drill bit. Any spotw-welds that weren't completely drilled out I used a air hammer to complete the separation. 1 of 6 Attached image(s) |
watsonrx13 |
Oct 8 2004, 05:17 PM
Here's a shot of the suspension welded in. I drilled 3/16" spot weld holes completely around the outside (only where it will be welded). You'll need to carefully fit the ear, which could entail bending or grinding, as needed.
3 of 4 Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 01:43 AM |
