| 914Sixer |
Jun 12 2016, 05:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,435 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I have the case buttoned up and torqued to spec for the 2056. The rotating assembly and the cam move like they should. I had a little trouble getting the oil pick up tube alignment but everything else is smooth. Next I dropped the drain sump cover and screen in. Moved on to put the taco plate and sender in. Up next was to install the oil pump, NOT happening (IMG:style_emoticons/default/headbang.gif) . So I look at everything and it looks ok, I don't see any to keep it from going in. I know it is a snug fit . I took the pump over to the wire wheel and evenly buffed around the pump housing 3 different times. Put some lube on the housing and the case, still no go. Case was line bored but it should not have made and difference in the oil pump area.
Keep buffing it down? |
| jeffdon |
Jun 12 2016, 06:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I have the case buttoned up and torqued to spec for the 2056. The rotating assembly and the cam move like they should. I had a little trouble getting the oil pick up tube alignment but everything else is smooth. Next I dropped the drain sump cover and screen in. Moved on to put the taco plate and sender in. Up next was to install the oil pump, NOT happening (IMG:style_emoticons/default/headbang.gif) . So I look at everything and it looks ok, I don't see any to keep it from going in. I know it is a snug fit . I took the pump over to the wire wheel and evenly buffed around the pump housing 3 different times. Put some lube on the housing and the case, still no go. Case was line bored but it should not have made and difference in the oil pump area. Keep buffing it down? Stop buffing. Make sure the pump drive tang is slotting into the cam. Hell, make sure the pump is going in right side up. Try loosening the case bolts on either side of the pump. Do not force it, but it may take some gentler "persuasion" to fully seat. |
914Sixer Stock Oil Pump Won't Fit Jun 12 2016, 05:36 PM
McMark :agree: Jun 12 2016, 06:50 PM
914Sixer This is not my 1st build. I have done about 15 en... Jun 12 2016, 10:08 PM
914_teener
This is not my 1st build. I have done about 15 e... Jun 12 2016, 10:13 PM
r_towle It happens.
Did they mill the case halves?
Otherwi... Jun 12 2016, 11:11 PM
r_towle And? Jun 18 2016, 06:45 PM
914Sixer Waiting on case spliter for oil pump. Should be h... Jun 19 2016, 05:56 AM
wndsrfr
Waiting on case spliter for oil pump. Should be ... Jun 19 2016, 06:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 10:52 AM |
