| JFG |
Jun 15 2016, 02:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I have a 1.7engine and will be running twin Weber 40idf's.
My car was originally a 2.0i but came minus engine and ancillaries. The only thing I have is the original 3 port pump. I haven't tested it yet but I won't be running a return so can't use the pumpin this instance. What kind of pressure should I be running the carbs at? Research and past experience (albeit not with 40's) would suggest something in the range of 2.5 to 3.5 psi. Anyone with this set up have any input/advice on pump and flow pressure? |
| rhodyguy |
Jun 15 2016, 02:50 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Find a low pressure, self regulated, 2 port pump and be done with it. Your stock fi pump, in serviceable condition, should cover the the cost.
JFG Fuel pressure twin carbs Jun 15 2016, 02:41 PM
brant Your experienced numbers are still good.
But I a... Jun 15 2016, 02:51 PM
SirAndy But I always recommend a return on carbs also
:a... Jun 15 2016, 02:55 PM
74ravenna
But I ... Jun 16 2016, 03:30 AM
SirAndy I just installed the fuel pump for carbs that i pu... Jun 16 2016, 11:09 AM
914Mike
I just installed the fuel pump for carbs that i p... Jun 17 2016, 09:52 PM
SirAndy Any thoughts on leaving the FI pump under the tank... Jun 17 2016, 09:59 PM
brant
Plenty of thoughts on both and them thoughts are ... Jun 17 2016, 10:15 PM
914Mike
Any thoughts on leaving the FI pump under the tan... Jun 20 2016, 09:07 AM
SirAndy I used this one on my 2056:
http://www.cbperforman... Jun 15 2016, 02:54 PM
North Coast Jim
http://www.cbperforma... Jun 15 2016, 03:01 PM
SirAndy Do you have pics of your installation. I am going ... Jun 15 2016, 03:22 PM
MarkV I used the factory wires but the previous owner cu... Jun 15 2016, 03:31 PM
JFG I've ordered one of the above mentioned pumps ... Jun 16 2016, 02:15 AM
Tbrown4x4
I've ordered one of the above mentioned pumps... Jun 16 2016, 07:25 AM
Elliot Cannon I've been using this setup for 13 years now. ... Jun 17 2016, 11:06 PM
rhodyguy With the facet and regulator you should still add ... Jun 20 2016, 10:05 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:32 AM |
