> "No start" SOLVED, Thanks, guys.
poorsche914
post Jun 17 2016, 10:49 AM
9fourteen
The engine: 2056 w/dual Webers; Mallory Unilite Distributor
The scene: caught in a severe downpour
The issue: started up but ran slightly rougher than usual but did smooth out. Drove ~3 miles home and, about a block from my house, I heard a "pop" and car died. Not sure if it was a carb backfire or something else. Coasted down the road and into the garage.
My relay board did not have a cover on it so I figured something got wet and caused the unilite module to pop. Ordered a new module and installed it. Still no start. Tested the module and it tested as good.
I then swapped out the relay and then the relay board and same result. Turn key, starter turns, but no start. Fuel pump is working. Coil tests OK at 3.5ohm across (+) and (-) Fuses on relay board and under dash are all good.
What else should I check? (IMG:style_emoticons/default/confused24.gif)
Thanks,
steve
dlee6204
post Jun 17 2016, 11:14 AM
Howdy
Do you have 12v at the coil? Have you confirmed that you are not getting spark?
poorsche914
post Jun 17 2016, 11:22 AM
9fourteen
QUOTE(dlee6204 @ Jun 17 2016, 01:14 PM) *
Yes, 12v at coil.
Have not confirmed spark... need to find a helper (IMG:style_emoticons/default/dry.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 11:15 AM
