Full Version: "No start" SOLVED
poorsche914
The engine: 2056 w/dual Webers; Mallory Unilite Distributor
The scene: caught in a severe downpour
The issue: started up but ran slightly rougher than usual but did smooth out. Drove ~3 miles home and, about a block from my house, I heard a "pop" and car died. Not sure if it was a carb backfire or something else. Coasted down the road and into the garage.
My relay board did not have a cover on it so I figured something got wet and caused the unilite module to pop. Ordered a new module and installed it. Still no start. Tested the module and it tested as good.
I then swapped out the relay and then the relay board and same result. Turn key, starter turns, but no start. Fuel pump is working. Coil tests OK at 3.5ohm across (+) and (-) Fuses on relay board and under dash are all good.
Thanks,
steve
dlee6204
Do you have 12v at the coil? Have you confirmed that you are not getting spark?
poorsche914
QUOTE(dlee6204 @ Jun 17 2016, 01:14 PM) *
Yes, 12v at coil.
Rand
Checking spark takes seconds, the quickest way to rule out half the potential rabbit trails. Pull a plug wire, stick a plug in it, ground the threads against the case, crank the starter, look for spark.
If you don't have a human helper, one of these is handy to have around:
http://www.harborfreight.com/12-volt-remot...itch-35448.html
poorsche914
QUOTE(Rand @ Jun 17 2016, 01:35 PM) *
Swapped out the coil, adjusted the timing, and it is now running.
steve
dlee6204
ConeDodger
Funny, before parts started getting made in China, coil failures were extremely rare. To the point that old school mechanics would probably check everything else twice before going to the coil...
r_towle
QUOTE(ConeDodger @ Jun 17 2016, 02:09 PM) *
I have OEM coils as spare parts to replace the new ones when they die
orthobiz
Have a new Bosch blue coil in mine, guess I'm not gonna sell my old one after all. It's going in the car!
Paul
poorsche914
Coil was an old school Bosch blue. I didn't check it first because I thought they were pretty much failsafe. But when I saw the weak spark, I thought it couldn't hurt to swap it out... with another old Bosch!
r_towle
Old school are the OEM ones...the blue ones are new tech.
