poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,139 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
The engine: 2056 w/dual Webers; Mallory Unilite Distributor
The scene: caught in a severe downpour The issue: started up but ran slightly rougher than usual but did smooth out. Drove ~3 miles home and, about a block from my house, I heard a "pop" and car died. Not sure if it was a carb backfire or something else. Coasted down the road and into the garage. My relay board did not have a cover on it so I figured something got wet and caused the unilite module to pop. Ordered a new module and installed it. Still no start. Tested the module and it tested as good. I then swapped out the relay and then the relay board and same result. Turn key, starter turns, but no start. Fuel pump is working. Coil tests OK at 3.5ohm across (+) and (-) Fuses on relay board and under dash are all good. What else should I check? (IMG:style_emoticons/default/confused24.gif) Thanks, steve (IMG:style_emoticons/default/driving.gif) |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
Do you have 12v at the coil? Have you confirmed that you are not getting spark?
poorsche914 |
Do you have 12v at the coil? Have you confirmed that you are not getting spark? Yes, 12v at coil. Have not confirmed spark... need to find a helper (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/driving.gif) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Checking spark takes seconds, the quickest way to rule out half the potential rabbit trails. Pull a plug wire, stick a plug in it, ground the threads against the case, crank the starter, look for spark.
If you don't have a human helper, one of these is handy to have around: http://www.harborfreight.com/12-volt-remot...itch-35448.html |
poorsche914 |
Checking spark takes seconds, the quickest way to rule out half the potential rabbit trails. Pull a plug wire, stick a plug in it, ground the threads against the case, crank the starter, look for spark. If you don't have a human helper, one of these is handy to have around: http://www.harborfreight.com/12-volt-remot...itch-35448.html Grabbed my daughter and had her crank. Very weak to no spark (IMG:style_emoticons/default/dry.gif) Swapped out the coil, adjusted the timing, and it is now running. Thanks for the assistance (IMG:style_emoticons/default/piratenanner.gif) steve (IMG:style_emoticons/default/driving.gif) |
dlee6204 |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,118 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Funny, before parts started getting made in China, coil failures were extremely rare. To the point that old school mechanics would probably check everything else twice before going to the coil...
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Funny, before parts started getting made in China, coil failures were extremely rare. To the point that old school mechanics would probably check everything else twice before going to the coil... I have OEM coils as spare parts to replace the new ones when they die |
orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
Have a new Bosch blue coil in mine, guess I'm not gonna sell my old one after all. It's going in the car!
Paul |
poorsche914 |
Funny, before parts started getting made in China, coil failures were extremely rare. To the point that old school mechanics would probably check everything else twice before going to the coil... Coil was an old school Bosch blue. I didn't check it first because I thought they were pretty much failsafe. But when I saw the weak spark, I thought it couldn't hurt to swap it out... with another old Bosch! (IMG:style_emoticons/default/driving.gif) |
Old school are the OEM ones...the blue ones are new tech.
Lo-Fi Version | Time is now: 30th July 2025 - 09:14 AM |
