| poorsche914 |
Jun 17 2016, 10:49 AM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
The engine: 2056 w/dual Webers; Mallory Unilite Distributor
The scene: caught in a severe downpour The issue: started up but ran slightly rougher than usual but did smooth out. Drove ~3 miles home and, about a block from my house, I heard a "pop" and car died. Not sure if it was a carb backfire or something else. Coasted down the road and into the garage. My relay board did not have a cover on it so I figured something got wet and caused the unilite module to pop. Ordered a new module and installed it. Still no start. Tested the module and it tested as good. I then swapped out the relay and then the relay board and same result. Turn key, starter turns, but no start. Fuel pump is working. Coil tests OK at 3.5ohm across (+) and (-) Fuses on relay board and under dash are all good. What else should I check? (IMG:style_emoticons/default/confused24.gif) Thanks, steve (IMG:style_emoticons/default/driving.gif) |
| ConeDodger |
Jun 17 2016, 12:09 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,396 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Funny, before parts started getting made in China, coil failures were extremely rare. To the point that old school mechanics would probably check everything else twice before going to the coil...
poorsche914 "No start" SOLVED Jun 17 2016, 10:49 AM
dlee6204 Do you have 12v at the coil? Have you confirmed t... Jun 17 2016, 11:14 AM
poorsche914
Do you have 12v at the coil? Have you confirmed ... Jun 17 2016, 11:22 AM
Rand Checking spark takes seconds, the quickest way to ... Jun 17 2016, 11:35 AM
poorsche914
Checking spark takes seconds, the quickest way to... Jun 17 2016, 11:46 AM
dlee6204 :thumbsup: Jun 17 2016, 12:04 PM
r_towle
Funny, before parts started getting made in China... Jun 17 2016, 12:21 PM
poorsche914
Funny, before parts started getting made in China... Jun 17 2016, 06:49 PM
orthobiz Have a new Bosch blue coil in mine, guess I'm ... Jun 17 2016, 04:54 PM
r_towle Old school are the OEM ones...the blue ones are ne... Jun 17 2016, 07:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:25 AM |
