| poorsche914 |
Jun 17 2016, 10:49 AM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
The engine: 2056 w/dual Webers; Mallory Unilite Distributor
The scene: caught in a severe downpour The issue: started up but ran slightly rougher than usual but did smooth out. Drove ~3 miles home and, about a block from my house, I heard a "pop" and car died. Not sure if it was a carb backfire or something else. Coasted down the road and into the garage. My relay board did not have a cover on it so I figured something got wet and caused the unilite module to pop. Ordered a new module and installed it. Still no start. Tested the module and it tested as good. I then swapped out the relay and then the relay board and same result. Turn key, starter turns, but no start. Fuel pump is working. Coil tests OK at 3.5ohm across (+) and (-) Fuses on relay board and under dash are all good. What else should I check? (IMG:style_emoticons/default/confused24.gif) Thanks, steve (IMG:style_emoticons/default/driving.gif) |
| orthobiz |
Jun 17 2016, 04:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
Have a new Bosch blue coil in mine, guess I'm not gonna sell my old one after all. It's going in the car!
Paul |
poorsche914 "No start" SOLVED Jun 17 2016, 10:49 AM
dlee6204 Do you have 12v at the coil? Have you confirmed t... Jun 17 2016, 11:14 AM
poorsche914
Do you have 12v at the coil? Have you confirmed ... Jun 17 2016, 11:22 AM
Rand Checking spark takes seconds, the quickest way to ... Jun 17 2016, 11:35 AM
poorsche914
Checking spark takes seconds, the quickest way to... Jun 17 2016, 11:46 AM
dlee6204 :thumbsup: Jun 17 2016, 12:04 PM
ConeDodger Funny, before parts started getting made in China,... Jun 17 2016, 12:09 PM
r_towle
Funny, before parts started getting made in China... Jun 17 2016, 12:21 PM
poorsche914
Funny, before parts started getting made in China... Jun 17 2016, 06:49 PM
r_towle Old school are the OEM ones...the blue ones are ne... Jun 17 2016, 07:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:03 AM |
