| 914Sixer |
Jun 12 2016, 05:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,435 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I have the case buttoned up and torqued to spec for the 2056. The rotating assembly and the cam move like they should. I had a little trouble getting the oil pick up tube alignment but everything else is smooth. Next I dropped the drain sump cover and screen in. Moved on to put the taco plate and sender in. Up next was to install the oil pump, NOT happening (IMG:style_emoticons/default/headbang.gif) . So I look at everything and it looks ok, I don't see any to keep it from going in. I know it is a snug fit . I took the pump over to the wire wheel and evenly buffed around the pump housing 3 different times. Put some lube on the housing and the case, still no go. Case was line bored but it should not have made and difference in the oil pump area.
Keep buffing it down? |
| r_towle |
Jun 18 2016, 06:45 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
And?
914Sixer Stock Oil Pump Won't Fit Jun 12 2016, 05:36 PM
jeffdon
I have the case buttoned up and torqued to spec f... Jun 12 2016, 06:44 PM
McMark :agree: Jun 12 2016, 06:50 PM
914Sixer This is not my 1st build. I have done about 15 en... Jun 12 2016, 10:08 PM
914_teener
This is not my 1st build. I have done about 15 e... Jun 12 2016, 10:13 PM
r_towle It happens.
Did they mill the case halves?
Otherwi... Jun 12 2016, 11:11 PM
914Sixer Waiting on case spliter for oil pump. Should be h... Jun 19 2016, 05:56 AM
wndsrfr
Waiting on case spliter for oil pump. Should be ... Jun 19 2016, 06:22 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 12:24 PM |
