| enf2232 |
Jun 18 2016, 03:58 PM
Member ![]() ![]() Group: Members Posts: 89 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
| Mikey914 |
Jun 18 2016, 11:11 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I suspect the hole is worn. Clean the roller slot and the pins on the worm drive, and add some epoxy between the two. May take up the slop, but replacing is the only way to fix it. I'm working on about new early version now.
enf2232 Window lift help Jun 18 2016, 03:58 PM
914Sixer Change your doors to 73 -76 ! 914Rubber makes... Jun 18 2016, 04:51 PM
enf2232 Thanks for the input. I thought I would try a pla... Jun 19 2016, 07:51 AM
r_towle You may have worn it past serviceable life.
You co... Jun 19 2016, 05:18 PM
bdstone914 If that is a drivers door I just pulled a good reg... Jun 19 2016, 10:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th July 2026 - 04:06 AM |
