WTB wheel spacers 1 pair, looking for about 1" wide |
jrblackbox |
Jun 24 2016, 05:47 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Anybody got a pair available for 4x130, will need bolts too, I have steel wheels. TIA
bdstone914 |
Jun 25 2016, 07:55 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Anybody got a pair available for 4x130, will need bolts too, I have steel wheels. TIA What wheels are you installing and why do you want to space them out? I have not seen 1" spacers for 4 lug. You would need 50mm long bolts. Have seen them either. You may want to go with adapters that bolt to the hubs.rotors and have studs that would use open end lug nuts. The rears are not hub-centric and spacers or adapters will exagerate the problem. Early front rotors are not hub-centric and lates are hub-centric. |
jrblackbox |
Jun 25 2016, 12:49 PM
Anybody got a pair available for 4x130, will need bolts too, I have steel wheels. TIA What wheels are you installing and why do you want to space them out? I have not seen 1" spacers for 4 lug. You would need 50mm long bolts. Have seen them either. You may want to go with adapters that bolt to the hubs.rotors and have studs that would use open end lug nuts. The rears are not hub-centric and spacers or adapters will exagerate the problem. Early front rotors are not hub-centric and lates are hub-centric. I want to put them on the front of a 71 to fill out the wheel well with my steelies. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:21 AM |
