> Another LED solution, ...seen on TheSamba
ThePaintedMan
post Jun 1 2016, 10:18 PM
$209 for the pair? Sounds too good to be true. Anyone have any experience with these?
http://www.thesamba.com/vw/classifieds/detail.php?id=1934155
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-13527-1464841158.1.jpg)
eric9144
post Jun 26 2016, 10:24 PM
Finally grabbed my keys and went back to the garage to test and... They are TOTALLY plug and play, only thing I may have to do is slightly adjust the beam height (down) but pretty good at install. Only had done the one to compare:
cooper951
post Jun 27 2016, 05:08 AM
QUOTE(eric9144 @ Jun 26 2016, 11:24 PM) *
Are these the $159 lights?
thomas@vintagecarleds.com
post Jun 27 2016, 07:00 AM
QUOTE(cooper951 @ Jun 27 2016, 06:08 AM) *
Yes, that's our VC2800 model.
Kansas 914
post Jun 27 2016, 07:05 AM
Does anyone have a "template" for aiming headlights on a 914?
Height of headlights and distance of the car from the wall would help. I know all of my cars are way off (either too high or too low - one of them might be a little cross-eyed)
I think this LED solution is very viable - thanks for the input from all.
anderssj
post Jun 27 2016, 07:29 AM
Dog is my copilot...
QUOTE(Kansas 914 @ Jun 27 2016, 09:05 AM) *
Kind of long, but very complete:
http://www.danielsternlighting.com/tech/aim/aim.html
Thanks for this thread--looks like it may be time to replace my Cibie e-code H4s . . .
post Jun 27 2016, 07:32 AM
QUOTE(anderssj @ Jun 27 2016, 08:29 AM) *
IMO Those Cibie H4 lenses are gold. I wouldn't get rid of them.
I know the bulbs our VC4000 kit uses would would perfectly in those lenses... Just not sure about the heatsink sitting in the back of the headlight bucket. You MAY have enough room...
anderssj
post Jun 27 2016, 07:59 AM
QUOTE(thomas@vintagecarleds.com @ Jun 27 2016, 09:32 AM) *
Thomas,
Thanks, that's a good idea. Would the VC4000 bulbs also work in other 9003/H4 formats (such as Marchal H4 4x6" as used in 4-light fox-body Mustang)? What about other H4 E-code lights (like Volvo 240 OEM euro lights)?
I think there may be a market for your LED bulbs in a variety of OEM H4/9003 applications--I'd be curious to see how they worked in place of the 9003/H4s currently in my bride's 1999 NB Miata . . . .
Thanks again!
Steve A-
post Jun 27 2016, 08:03 AM
[quote name='anderssj' date='Jun 27 2016, 08:59 AM' post='2364540']
[/quote]
Thomas,
Thanks again!
Steve A-
[/quote]
Steve, Our VC4000 bulbs use the H4 base style, and the LED's themselves are laid out on the "bulb" in the same location/pattern as a filament style H4. (for proper focal length)
I have never tested them on a Fox Body Mustang since I do not own one, But assuming the car takes H4 Bulbs, and has juuuuust enough room behind the headlight housing for the heatsink, I would see no problem with them fitting.
Same thing for the H4 E-Codes, the VC4000 bulb works great if you have quality E-Code lenses like those Cibies or Hellas. I have tested our VC4000 bulbs with lower-quality cheap E-code lenses, and they did a terrible job at distributing the beam.
So I always Like to "warn" people who buy bulbs alone from us, that they must have a quality lens for them to work properly.
ThePaintedMan   Another LED solution   Jun 1 2016, 10:18 PM
bandjoey   But I don't think it will fit into the tight b...   Jun 1 2016, 10:22 PM
Mueller   I thought that was a household 110v plug at 1st :)   Jun 1 2016, 10:23 PM
eric9144   Wow and a claim of 4000 lumen output! :popco...   Jun 1 2016, 10:33 PM
matthepcat   Cool. I would need to see a beam pattern before bu...   Jun 1 2016, 10:36 PM
ThePaintedMan   I have a sneaking suspicion that they might actual...   Jun 1 2016, 10:42 PM
RobW   Looks promising. Some modification would be requir...   Jun 1 2016, 10:42 PM
eric9144   The other model they sell is even cheaper, still a...   Jun 1 2016, 10:47 PM
matthepcat   The other model they sell is even cheaper, still ...   Jun 1 2016, 11:21 PM
mrholland2   [quote name='eric9144' post='2353442' date='Jun 1...   Jun 2 2016, 10:52 AM
eric9144   [quote name='eric9144' post='2353442' date='Jun ...   Jun 2 2016, 11:06 AM
bandjoey   Is there a law covering how bright the lights can ...   Jun 2 2016, 11:39 AM
matthepcat   The "ricer lights" you see ...also on li...   Jun 2 2016, 12:41 PM
mrholland2   The "ricer lights" you see ...also on l...   Jun 3 2016, 05:26 PM
matthepcat   Here is a basic overview ( Leaves out some details...   Jun 3 2016, 06:49 PM
eric9144   BULB TYPE WATTAGE LUMENS (high/low) 9003/HB2 60/55...   Jun 2 2016, 12:02 PM
JamesM   $209 for the pair? Sounds too good to be tru...   Jun 2 2016, 01:26 PM
JamesM   Bolt on, nothing else needed http://www.amazon.c...   Jun 2 2016, 01:32 PM
87m491   Could be the picture angles, but those lenses look...   Jun 3 2016, 11:12 AM
thomas@vintagecarleds.com   Could be the picture angles, but those lenses loo...   Jun 3 2016, 11:21 AM
87m491   Yes I see the design, by "flat" I was re...   Jun 3 2016, 01:16 PM
JamesM   Could be the picture angles, but those lenses loo...   Jun 3 2016, 02:01 PM
thomas@vintagecarleds.com   [quote name='87m491' post='2354173' date='Jun 3 2...   Jun 3 2016, 02:07 PM
RobW   Nice. Any issues installing on the 914?   Jun 2 2016, 01:28 PM
JamesM   Nice. Any issues installing on the 914? No issu...   Jun 2 2016, 01:35 PM
mepstein   Nice. Any issues installing on the 914? No iss...   Jun 2 2016, 07:07 PM
Mark Henry   I've looked into it....they won't fit on t...   Jun 2 2016, 02:02 PM
Mark Henry   BTW the average LED headlight bulb will lose about...   Jun 2 2016, 02:06 PM
NeunEinVier   BTW the average LED headlight bulb will lose abou...   Jun 16 2016, 12:43 PM
Mark Henry   BTW the average LED headlight bulb will lose abo...   Jun 16 2016, 12:55 PM
porschetub   superbrightled have a kit for the 914,so no fitmen...   Jun 2 2016, 02:07 PM
matthepcat   Was it just an LED bulb...or a whole housing? Did...   Jun 2 2016, 02:09 PM
eric9144   I've looked into it....they won't fit on ...   Jun 2 2016, 02:20 PM
matthepcat   If Mark Henry is correct about the housings, I bet...   Jun 2 2016, 06:42 PM
thomas@vintagecarleds.com   Hi guys, If you have any questions about our produ...   Jun 3 2016, 10:30 AM
87m491   I have "E" code lamps on all my old cars...   Jun 3 2016, 11:19 AM
thomas@vintagecarleds.com   I have "E" code lamps on all my old car...   Jun 3 2016, 11:23 AM
87m491   Sweet. That's what I'm talking about...   Jun 3 2016, 01:29 PM
eric9144   So Thomas, thanks for chiming in, here's my qu...   Jun 3 2016, 11:02 AM
thomas@vintagecarleds.com   So Thomas, thanks for chiming in, here's my q...   Jun 3 2016, 11:18 AM
gandalf_025   New member joining just to sell something... Alwa...   Jun 3 2016, 11:37 AM
thomas@vintagecarleds.com   New member joining just to sell something... Alw...   Jun 3 2016, 11:41 AM
gandalf_025   New member joining just to sell something... Al...   Jun 3 2016, 12:21 PM
thomas@vintagecarleds.com   Thanks for replying... I respect your honesty.....   Jun 3 2016, 12:28 PM
76-914   Thanks for replying... I respect your honesty....   Jun 3 2016, 12:55 PM
thomas@vintagecarleds.com   [quote name='thomas@vintagecarleds.com' post='235...   Jun 3 2016, 01:08 PM
ThePaintedMan   Thomas, you're all good. I think most of us we...   Jun 3 2016, 12:23 PM
thomas@vintagecarleds.com   Any chance you'd be willing to send a pair o...   Jun 3 2016, 12:30 PM
87m491   Can you expand on the bulbs mentioned? I see the ...   Jun 3 2016, 01:26 PM
thomas@vintagecarleds.com   Can you expand on the bulbs mentioned? I see the...   Jun 3 2016, 01:30 PM
Red72   Can you expand on the bulbs mentioned? I see th...   Jun 22 2016, 06:21 PM
thomas@vintagecarleds.com   [quote name='thomas@vintagecarleds.com' post='235...   Jun 23 2016, 10:07 AM
Red72   [quote name='thomas@vintagecarleds.com' ...   Jun 26 2016, 12:47 PM
thomas@vintagecarleds.com   Perfect! Your website doesn't appear t...   Jun 27 2016, 06:59 AM
eric9144   Can you expand on the bulbs mentioned? I see th...   Jun 3 2016, 01:49 PM
thomas@vintagecarleds.com   Oh BTW, People ask me if I carry LED brake lights....   Jun 3 2016, 02:23 PM
Wyvern   Did anyone here try a product from this vendor? ...   Jun 16 2016, 09:12 AM
Mikey914   We saw these bulbs at SEMA, and from what we could...   Jun 16 2016, 09:32 AM
eric9144   My set of 2800's arrived, haven't had a ch...   Jun 16 2016, 09:43 AM
Mikey914   What we saw was not the the light unit didn't ...   Jun 16 2016, 09:45 AM
bandjoey   If someone has nothing else to do the alibaba web...   Jun 16 2016, 10:20 AM
Mark Henry   Thomas have you fitted these into a 914? The 914 ...   Jun 16 2016, 12:57 PM
NeunEinVier   Interesting, didn't realize LED technology had...   Jun 16 2016, 01:08 PM
Chris914n6   One thing to note is that LEDs don't put out l...   Jun 16 2016, 11:46 PM
87m491   One thing to note is that LEDs don't put out ...   Jun 23 2016, 11:32 AM
mepstein   [quote name='Chris914n6' post='2360440' date='Jun...   Jun 23 2016, 03:38 PM
eric9144   I should be attempting install this week---Fathers...   Jun 23 2016, 11:00 AM
Kansas 914   I'm still very optimistic they'll be plug...   Jun 23 2016, 11:04 AM
thomas@vintagecarleds.com   I should be attempting install this week---Father...   Jun 23 2016, 11:28 AM
Chris Pincetich   :wttc: I installed GE nighthawks last Fall and th...   Jun 23 2016, 02:57 PM
eric9144   Well I can answer one question--They DO fit. I di...   Jun 24 2016, 09:35 AM
thomas@vintagecarleds.com   if they require re-wiring its a deal breaker, I...   Jun 25 2016, 12:59 PM
eric9144   Finally grabbed my keys and went back to the garag...   Jun 26 2016, 10:24 PM
cooper951   Finally grabbed my keys and went back to the gara...   Jun 27 2016, 05:08 AM
thomas@vintagecarleds.com   Are these the $159 lights? Yes, that...   Jun 27 2016, 07:00 AM
Kansas 914   Does anyone have a "template" for aiming...   Jun 27 2016, 07:05 AM
mepstein   Does anyone have a "template" for aimin...   Jun 27 2016, 07:23 AM
Kansas 914   When you say all your cars do you mean 914's...   Jun 27 2016, 07:27 AM
thomas@vintagecarleds.com   I suppose I could use one of my "regular...   Jun 27 2016, 07:31 AM
Kansas 914   A general rule of thumb is all headlights no matt...   Jun 27 2016, 07:44 AM
thomas@vintagecarleds.com   A general rule of thumb is all headlights no mat...   Jun 27 2016, 07:49 AM
anderssj   Does anyone have a "template" for aimin...   Jun 27 2016, 07:29 AM
thomas@vintagecarleds.com   Does anyone have a "template" for aimi...   Jun 27 2016, 07:32 AM
anderssj   [quote name='anderssj' post='2364525' date='Jun 2...   Jun 27 2016, 07:59 AM
thomas@vintagecarleds.com   IMO Those Cibie H4 lenses are gold. I wouldn...   Jun 27 2016, 08:03 AM
Kansas 914   Kind of long, but very complete: http://www.dan...   Jun 27 2016, 07:45 AM
eric9144   Now we just need a drop in replacement for the fog...   Jun 27 2016, 09:50 AM
Amphicar770   This evening I installed a set of Optix LED's ...   Jul 2 2016, 09:34 PM
thomas@vintagecarleds.com   This evening I installed a set of Optix LED's...   Jul 3 2016, 11:45 AM
mepstein   This evening I installed a set of Optix LED...   Jul 3 2016, 12:08 PM
thomas@vintagecarleds.com   [quote name='thomas@vintagecarleds.com' post='236...   Jul 3 2016, 03:53 PM
Amphicar770   Those work pretty well, I imported some from Chin...   Jul 3 2016, 01:13 PM
thomas@vintagecarleds.com   [quote name='thomas@vintagecarleds.com' post='236...   Jul 3 2016, 03:54 PM
Amphicar770   This evening I installed a set of Optix LED's...   Jul 22 2016, 09:56 PM
rothaus   Here is another option. http://www.914world.com/b...   Jul 4 2016, 05:50 AM
amfab   Just bought a pair of Anzos from Autoanything (no ...   Jul 22 2016, 10:44 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:14 PM
