> Car Has No Compression On #4, ...can I take the valve cover off without draining oil?
7TPorsh
post Jun 30 2016, 12:30 PM
7T Porsh
A problem has recenly developed and I can't figure it out. The car starts up easy and on the first crank. I let it warm up a few minutes and drive....It drives fine as it's warming up.
Then after about 15 or 20 minutes the engine starts developing a shudder. Idles fine but and can run ok under low load but under some load the #4 cylinder starts popping and firing up through the carb. feels like it's running 3 cylinders and wasting gas.
It's been suggested I do a compression test but I'm thinking if the engine runs great cold and while warmin up; the compression should be ok.
Is there a case where comprression is ok when cold but low when hot? Can't figure out why car runs great when starts f'n up.
1.7 with dual weber 40 IDFs
7TPorsh   Car Has No Compression On #4   Jun 30 2016, 12:30 PM
JmuRiz   Sounds the opposite of a properly setup carb engin...   Jun 30 2016, 01:19 PM
7TPorsh   Did a compression test tonight.... 105 / 105 / 105...   Jun 30 2016, 11:02 PM
The Cabinetmaker   Squirt some oil in the plug hole then retest compr...   Jul 1 2016, 06:43 AM
7TPorsh   Squirt some oil in the plug hole then retest comp...   Jul 1 2016, 08:24 AM
Mark Henry   Squirt some oil in the plug hole then retest com...   Jul 1 2016, 09:26 AM
rfinegan   Sounds like a tight valve ( held open) adjust and ...   Jul 1 2016, 08:53 AM
7TPorsh   Sounds like a tight valve ( held open) adjust and...   Jul 8 2016, 09:58 AM
BK911   Leakdown   Jul 1 2016, 10:44 AM
JmuRiz   :agree: Leakdown will tell where the issue is, ri...   Jul 1 2016, 01:15 PM
era vulgaris   You don't need to drain the oil to remove the ...   Jul 8 2016, 11:45 AM
Jetsetsurfshop   You don't need to drain the oil to remove the...   Jul 8 2016, 02:01 PM
ThePaintedMan   ? you do not have to drain the oil to take a valv...   Jul 8 2016, 12:15 PM
stugray   Leakdown test only works if you have SOME compress...   Jul 8 2016, 12:25 PM
HAM Inc   Do a leakdown test. It will tell you where the lea...   Jul 8 2016, 12:42 PM
Dave_Darling   Look at the valve tips when each cylinder is on TD...   Jul 8 2016, 02:49 PM
jcd914   Look at the valve tips when each cylinder is on T...   Jul 8 2016, 05:16 PM
76-914   Look at the valve tips when each cylinder is on T...   Jul 8 2016, 05:26 PM
- Lo-Fi Version Time is now: 17th June 2024 - 06:47 AM
