> Terrible Scraping Noise
TX914
post Jul 1 2016, 06:14 AM
Alan-B
Went for a short run around the neighborhood and stopped for gas. When I restarted there was a terrible scraping noise so I shut it off immediately. Sounded to me like a piece of engine tin or casing scraping on the impeller…
Tried restarting a couple of times with same result. Clutch in/out made no difference, and I was afraid to rev it. Oil level okay, and nothing loose in/around the impeller. I decided to drive it gently away to the side so I could tow it home for closer inspection. Restarted and drove in reverse for a few feet which made no difference, but then pulling forward for a few feet the scraping suddenly stopped. All seemed normal again so I drove it home – it idled fine, had good power and haven’t heard the noise since. I’m looking for ideas as to what the scraping sound might have been. Anyone experienced that before? It’s a ’76 with stock FI 2.0. It does have a relatively new starter.
ThePaintedMan
post Jul 1 2016, 06:17 AM
Make sure there is nothing down by the impeller. Debris, etc does happen from time to time. Also make sure it wasn't the coil vibrating loose and rubbing against the impeller (BTDT).
Finally, check the torque on the impeller bolts and make sure it's not walking out of the "cage".
- Lo-Fi Version Time is now: 26th July 2026 - 01:04 PM
