Rathguten |
Newbie ![]() Group: Members Posts: 9 Joined: 17-May 16 From: Hialeah,FL Member No.: 20,003 Region Association: None ![]() |
Hi folks!
I turned on my headlights and they both popped up. When I turned them off, the right one went all the way down but the left side stayed halfway up. I turned the lights on again and the right side popped up correctly, but the left side cycled back down before popping back up and resting in the correct position. I played with the headlight switch, pushing it in and out while the lights "danced", one up, the other down, so on a so forth and then both closed. Now when I turn the headlight switch on the bulbs turn on, but the lights don't pop up at all. I tried searching the forum for an answer, but I either don't know how to search or the search function isn't very good. Any help would be greatly appreciated. |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
One switch works both headlight motors. . . If only one is malfunctioning it is that motor or linkage issue
Lo-Fi Version | Time is now: 6th July 2025 - 10:49 PM |
