| ThePaintedMan |
Jun 1 2016, 10:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
$209 for the pair? Sounds too good to be true. Anyone have any experience with these?
http://www.thesamba.com/vw/classifieds/detail.php?id=1934155 (IMG:http://www.914world.com/bbs2/uploads_offsite/images.thesamba.com-13527-1464841158.1.jpg) |
| Amphicar770 |
Jul 2 2016, 09:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
This evening I installed a set of Optix LED's on my 914. They appear to be Chinese clones of the Truck-ltes. With an ebay coupon for $20 off, they came to $114 for the pair. Even without coupon, $134 seems pretty inexpensive.
All I can say is WOW! I compared the first one next to the Hella H4. No pun intended but a night and day difference. Install was a breeze. The cable connector easily tucked in above the headlight so no worries about it getting caught up in the door. Here is the link for the ones I bought. Sorry, the coupon was a targeted ebay motors promo. http://www.ebay.com/itm/381638605165 |
| thomas@vintagecarleds.com |
Jul 3 2016, 11:45 AM
Newbie ![]() Group: Members Posts: 36 Joined: 3-June 16 From: Houston Member No.: 20,065 Region Association: None |
This evening I installed a set of Optix LED's on my 914. They appear to be Chinese clones of the Truck-ltes. With an ebay coupon for $20 off, they came to $114 for the pair. Even without coupon, $134 seems pretty inexpensive. All I can say is WOW! I compared the first one next to the Hella H4. No pun intended but a night and day difference. Install was a breeze. The cable connector easily tucked in above the headlight so no worries about it getting caught up in the door. Here is the link for the ones I bought. Sorry, the coupon was a targeted ebay motors promo. http://www.ebay.com/itm/381638605165 Those work pretty well, I imported some from China too. I would like to warn you, the outer plastic lens will start yellowing after 6 months. To avoid that, install headlight protectant film, which has a UV coating. Look for a 2015 Jeep Wrangler, as that have the same headlights, that film will apply to those and help protect the plastic. http://www.xpel.com/headlight-protection-kits/ |
| Amphicar770 |
Jul 3 2016, 01:13 PM
Those work pretty well, I imported some from China too. I would like to warn you, the outer plastic lens will start yellowing after 6 months. To avoid that, install headlight protectant film, which has a UV coating. Look for a 2015 Jeep Wrangler, as that have the same headlights, that film will apply to those and help protect the plastic. http://www.xpel.com/headlight-protection-kits/ Given that I probably do less than an hour of night driving per year in the 914, I'll hopefully be good for a while. Maybe by then, Nighthawks will be going for $30 a pair at the local FLAPS. |
ThePaintedMan Another LED solution Jun 1 2016, 10:18 PM
bandjoey But I don't think it will fit into the tight b... Jun 1 2016, 10:22 PM
Mueller I thought that was a household 110v plug at 1st :) Jun 1 2016, 10:23 PM
eric9144 Wow and a claim of 4000 lumen output! :popco... Jun 1 2016, 10:33 PM
matthepcat Cool. I would need to see a beam pattern before bu... Jun 1 2016, 10:36 PM
ThePaintedMan I have a sneaking suspicion that they might actual... Jun 1 2016, 10:42 PM
RobW Looks promising. Some modification would be requir... Jun 1 2016, 10:42 PM
eric9144 The other model they sell is even cheaper, still a... Jun 1 2016, 10:47 PM
matthepcat
The other model they sell is even cheaper, still ... Jun 1 2016, 11:21 PM
mrholland2
[quote name='eric9144' post='2353442' date='Jun 1... Jun 2 2016, 10:52 AM
eric9144
[quote name='eric9144' post='2353442' date='Jun ... Jun 2 2016, 11:06 AM
bandjoey Is there a law covering how bright the lights can ... Jun 2 2016, 11:39 AM
matthepcat The "ricer lights" you see ...also on li... Jun 2 2016, 12:41 PM
mrholland2
The "ricer lights" you see ...also on l... Jun 3 2016, 05:26 PM
matthepcat Here is a basic overview ( Leaves out some details... Jun 3 2016, 06:49 PM
eric9144 BULB TYPE WATTAGE LUMENS (high/low)
9003/HB2 60/55... Jun 2 2016, 12:02 PM
JamesM
$209 for the pair? Sounds too good to be tru... Jun 2 2016, 01:26 PM
JamesM Bolt on, nothing else needed
http://www.amazon.c... Jun 2 2016, 01:32 PM
87m491 Could be the picture angles, but those lenses look... Jun 3 2016, 11:12 AM
Could be the picture angles, but those lenses loo... Jun 3 2016, 11:21 AM
87m491 Yes I see the design, by "flat" I was re... Jun 3 2016, 01:16 PM
JamesM
Could be the picture angles, but those lenses loo... Jun 3 2016, 02:01 PM
[quote name='87m491' post='2354173' date='Jun 3 2... Jun 3 2016, 02:07 PM
RobW Nice. Any issues installing on the 914? Jun 2 2016, 01:28 PM
JamesM
No issu... Jun 2 2016, 01:35 PM
No iss... Jun 2 2016, 07:07 PM
Mark Henry I've looked into it....they won't fit on t... Jun 2 2016, 02:02 PM
Mark Henry BTW the average LED headlight bulb will lose about... Jun 2 2016, 02:06 PM
NeunEinVier
BTW the average LED headlight bulb will lose abou... Jun 16 2016, 12:43 PM
Mark Henry
BTW the average LED headlight bulb will lose abo... Jun 16 2016, 12:55 PM
porschetub superbrightled have a kit for the 914,so no fitmen... Jun 2 2016, 02:07 PM
matthepcat Was it just an LED bulb...or a whole housing?
Did... Jun 2 2016, 02:09 PM
eric9144
I've looked into it....they won't fit on ... Jun 2 2016, 02:20 PM
matthepcat If Mark Henry is correct about the housings, I bet... Jun 2 2016, 06:42 PM
thomas@vintagecarleds.com Hi guys, If you have any questions about our produ... Jun 3 2016, 10:30 AM
87m491 I have "E" code lamps on all my old cars... Jun 3 2016, 11:19 AM
I have "E" code lamps on all my old car... Jun 3 2016, 11:23 AM
87m491 Sweet. That's what I'm talking about... Jun 3 2016, 01:29 PM
eric9144 So Thomas, thanks for chiming in, here's my qu... Jun 3 2016, 11:02 AM
So Thomas, thanks for chiming in, here's my q... Jun 3 2016, 11:18 AM
gandalf_025 New member joining just to sell something... Alwa... Jun 3 2016, 11:37 AM
New member joining just to sell something... Alw... Jun 3 2016, 11:41 AM
gandalf_025
New member joining just to sell something... Al... Jun 3 2016, 12:21 PM
Thanks for replying... I respect your honesty..... Jun 3 2016, 12:28 PM
76-914
Thanks for replying... I respect your honesty.... Jun 3 2016, 12:55 PM
[quote name='thomas@vintagecarleds.com' post='235... Jun 3 2016, 01:08 PM
ThePaintedMan Thomas, you're all good. I think most of us we... Jun 3 2016, 12:23 PM
Any chance you'd be willing to send a pair o... Jun 3 2016, 12:30 PM
87m491 Can you expand on the bulbs mentioned? I see the ... Jun 3 2016, 01:26 PM
Can you expand on the bulbs mentioned? I see the... Jun 3 2016, 01:30 PM
Red72
Can you expand on the bulbs mentioned? I see th... Jun 22 2016, 06:21 PM
[quote name='thomas@vintagecarleds.com' post='235... Jun 23 2016, 10:07 AM
Red72
[quote name='thomas@vintagecarleds.com' ... Jun 26 2016, 12:47 PM
Perfect! Your website doesn't appear t... Jun 27 2016, 06:59 AM
eric9144
Can you expand on the bulbs mentioned? I see th... Jun 3 2016, 01:49 PM
thomas@vintagecarleds.com Oh BTW, People ask me if I carry LED brake lights.... Jun 3 2016, 02:23 PM
Wyvern Did anyone here try a product from this vendor? ... Jun 16 2016, 09:12 AM
Mikey914 We saw these bulbs at SEMA, and from what we could... Jun 16 2016, 09:32 AM
eric9144 My set of 2800's arrived, haven't had a ch... Jun 16 2016, 09:43 AM
Mikey914 What we saw was not the the light unit didn't ... Jun 16 2016, 09:45 AM
bandjoey If someone has nothing else to do the alibaba web... Jun 16 2016, 10:20 AM
Mark Henry Thomas have you fitted these into a 914?
The 914 ... Jun 16 2016, 12:57 PM
NeunEinVier Interesting, didn't realize LED technology had... Jun 16 2016, 01:08 PM
Chris914n6 One thing to note is that LEDs don't put out l... Jun 16 2016, 11:46 PM
87m491
One thing to note is that LEDs don't put out ... Jun 23 2016, 11:32 AM
[quote name='Chris914n6' post='2360440' date='Jun... Jun 23 2016, 03:38 PM
eric9144 I should be attempting install this week---Fathers... Jun 23 2016, 11:00 AM
Kansas 914
I'm still very optimistic they'll be plug... Jun 23 2016, 11:04 AM
I should be attempting install this week---Father... Jun 23 2016, 11:28 AM
Chris Pincetich :wttc:
I installed GE nighthawks last Fall and th... Jun 23 2016, 02:57 PM
eric9144 Well I can answer one question--They DO fit. I di... Jun 24 2016, 09:35 AM
if they require re-wiring its a deal breaker, I... Jun 25 2016, 12:59 PM
eric9144 Finally grabbed my keys and went back to the garag... Jun 26 2016, 10:24 PM
cooper951
Finally grabbed my keys and went back to the gara... Jun 27 2016, 05:08 AM
Are these the $159 lights?
Yes, that... Jun 27 2016, 07:00 AM
Kansas 914 Does anyone have a "template" for aiming... Jun 27 2016, 07:05 AM
Does anyone have a "template" for aimin... Jun 27 2016, 07:23 AM
Kansas 914
When you say all your cars do you mean 914's... Jun 27 2016, 07:27 AM
I suppose I could use one of my "regular... Jun 27 2016, 07:31 AM
Kansas 914
A general rule of thumb is all headlights no matt... Jun 27 2016, 07:44 AM
A general rule of thumb is all headlights no mat... Jun 27 2016, 07:49 AM
anderssj
Does anyone have a "template" for aimin... Jun 27 2016, 07:29 AM
Does anyone have a "template" for aimi... Jun 27 2016, 07:32 AM
anderssj
[quote name='anderssj' post='2364525' date='Jun 2... Jun 27 2016, 07:59 AM
IMO Those Cibie H4 lenses are gold. I wouldn... Jun 27 2016, 08:03 AM
Kansas 914
Kind of long, but very complete:
http://www.dan... Jun 27 2016, 07:45 AM
eric9144 Now we just need a drop in replacement for the fog... Jun 27 2016, 09:50 AM
This evening I installed a set of Optix LED... Jul 3 2016, 12:08 PM
[quote name='thomas@vintagecarleds.com' post='236... Jul 3 2016, 03:53 PM
[quote name='thomas@vintagecarleds.com' post='236... Jul 3 2016, 03:54 PM
Amphicar770
This evening I installed a set of Optix LED's... Jul 22 2016, 09:56 PM
rothaus Here is another option.
http://www.914world.com/b... Jul 4 2016, 05:50 AM
amfab Just bought a pair of Anzos from Autoanything (no ... Jul 22 2016, 10:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:14 PM |
