7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
A problem has recenly developed and I can't figure it out. The car starts up easy and on the first crank. I let it warm up a few minutes and drive....It drives fine as it's warming up.
Then after about 15 or 20 minutes the engine starts developing a shudder. Idles fine but and can run ok under low load but under some load the #4 cylinder starts popping and firing up through the carb. feels like it's running 3 cylinders and wasting gas. It's been suggested I do a compression test but I'm thinking if the engine runs great cold and while warmin up; the compression should be ok. Is there a case where comprression is ok when cold but low when hot? Can't figure out why car runs great when starts f'n up. 1.7 with dual weber 40 IDFs |
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
? you do not have to drain the oil to take a valve cover off.
Lo-Fi Version | Time is now: 17th June 2024 - 06:42 AM |
