WTB: Tach Glass, Want to Convert from Plastic |
914Sixer |
Jul 22 2016, 06:22 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Need the glass from an non working tach. No chips or pits.
pete000 |
Jul 23 2016, 11:30 AM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Could someone post a how to remove thE bezel on the gauge without messing up the bezel. I tried once and failed big time.
Tjmrfe |
Jul 25 2016, 03:51 PM
NON IMPEDING RATIONE COGITATIONIS Group: Members Posts: 132 Joined: 10-April 15 From: Cornwall on Hudson, New York Member No.: 18,612 Region Association: North East States |
Could someone post a how to remove thE bezel on the gauge without messing up the bezel. I tried once and failed big time. I just did mine, put those cool white face gauge faces on....craftsman sells a good "wiring" screwdriver, you take it, perpendicular to the body & peel the rim up, once I had a good bit up, I worked the edge like an old fashion can opener, pivoting the screwdriver using the speedo body as leverage. I went once all the way around. And then gently pry at a few opposing spots to "pop" over the edge of the speedo rim....it is not for the UN-patient...I messed my 1st trim up a little, but the rubber edge hid most of my mistakes, and the rest (and I did the small center ones as well) came out great, got the white faces on, and with the new LED bulbs, it's like super cool....good luck. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:19 AM |
