QUOTE(pete000 @ Jul 23 2016, 09:30 AM)
Could someone post a how to remove thE bezel on the gauge without messing up the bezel. I tried once and failed big time.
I just did mine, put those cool white face gauge faces on....craftsman sells a good "wiring" screwdriver, you take it, perpendicular to the body & peel the rim up, once I had a good bit up, I worked the edge like an old fashion can opener, pivoting the screwdriver using the speedo body as leverage. I went once all the way around. And then gently pry at a few opposing spots to "pop" over the edge of the speedo rim....it is not for the UN-patient...I messed my 1st trim up a little, but the rubber edge hid most of my mistakes, and the rest (and I did the small center ones as well) came out great, got the white faces on, and with the new LED bulbs, it's like super cool....good luck.
