Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
'73-914kid |
Jul 24 2016, 07:13 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out.
Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) |
Elliot Cannon |
Jul 26 2016, 12:00 AM
[quote name=''73-914kid' date='Jul 24 2016, 06:13 PM' post='2375964']
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out. Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) [/quote I soaked it in oil for a few hours and re-installed it. It looks like that might have done the trick. Thanks for the tip. |
JamesM |
Jul 26 2016, 10:21 AM
Senior Member Group: Members Posts: 1,916 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
[quote name='Elliot Cannon' date='Jul 25 2016, 10:00 PM' post='2376554']
[quote name=''73-914kid' date='Jul 24 2016, 06:13 PM' post='2375964'] Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out. Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) [/quote I soaked it in oil for a few hours and re-installed it. It looks like that might have done the trick. Thanks for the tip. [/quote] Keep a close eye on it. watched a local teener burst into flames at the last autocross after it lost a plug from a carb. Needless to say it didnt help my opinion of carbs.... |
Lo-Fi Version | Time is now: 10th June 2024 - 11:25 PM |
