[quote name='Elliot Cannon' date='Jul 25 2016, 10:00 PM' post='2376554']
[quote name=''73-914kid' date='Jul 24 2016, 06:13 PM' post='2375964']
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out.
Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers...
[/quote
I soaked it in oil for a few hours and re-installed it. It looks like that might have done the trick. Thanks for the tip.
[/quote]
Keep a close eye on it. watched a local teener burst into flames at the last autocross after it lost a plug from a carb. Needless to say it didnt help my opinion of carbs....
