Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
'73-914kid |
Jul 24 2016, 07:13 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out.
Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) |
Mark Henry |
Jul 24 2016, 07:14 PM
Threebond 1104, Yamabond is the same thing except rebranded by Yamaha.
Light bead on each side of the aluminum or fiber washer. |
type2man |
Jul 24 2016, 08:00 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Try loosening and tightening it softly a couple of times to set the gaskets in place
Jul 24 2016, 08:38 PM
Custom Member Group: Members Posts: 24,565 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If with the gasket in place you have a leak, most likely you have some damage of th mating surfaces.
Typically, unless it's a huge gash, the gasket will make up for,the difference... Are you using a gasket there? What type? Is it the right filter or maybe it's holding the part. Just a hair. I know there are what, 10 different accelerator pumps for them....maybe there are multiple filters and you got one too tall. |
Elliot Cannon |
Jul 24 2016, 09:35 PM
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out. Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) It's a fiber washer. I'm trying the "leave it overnight and tighten it the next day" method. Only because I didn't know what else to do. (IMG:style_emoticons/default/laugh.gif) If it still doesn't work I'll try soaking it. |
Elliot Cannon |
Jul 24 2016, 09:39 PM
If with the gasket in place you have a leak, most likely you have some damage of th mating surfaces. Typically, unless it's a huge gash, the gasket will make up for,the difference... Are you using a gasket there? What type? Is it the right filter or maybe it's holding the part. Just a hair. I know there are what, 10 different accelerator pumps for them....maybe there are multiple filters and you got one too tall. I thought it might be the filter but it's the same filter that was in it. The one in the overhaul kit was damaged. Both mating surfaces seemed clean and smooth. Interestingly, the one on the other carb. was leaking as well. Tightened it a little and the leak stopped. Could be that the gaskets just got dry?? The car has sat since the rt66 "freeze your ass off in Arizona tour". (IMG:style_emoticons/default/av-943.gif) |
Jul 24 2016, 10:06 PM
Jbweld.....had to be said.
Elliot Cannon |
Jul 24 2016, 10:37 PM
Elliot Cannon |
Jul 26 2016, 12:00 AM
[quote name=''73-914kid' date='Jul 24 2016, 06:13 PM' post='2375964']
Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out. Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) [/quote I soaked it in oil for a few hours and re-installed it. It looks like that might have done the trick. Thanks for the tip. |
JamesM |
Jul 26 2016, 10:21 AM
Senior Member Group: Members Posts: 1,890 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
[quote name='Elliot Cannon' date='Jul 25 2016, 10:00 PM' post='2376554']
[quote name=''73-914kid' date='Jul 24 2016, 06:13 PM' post='2375964'] Cooper crush washer, or the red fiber crush washer? If it's a fiber crush washer, soak it in low viscosity motor oil or gasoline for an hour. Wipe off the excess oil, and reinstall. Soaking it in gas or oil allows the fiber washer to swell up, and facilitates sealing. To be honest, if you left it sit overnight, then tightened it a little bit in the morning, it would seal, but this method guarantees it will seal the first time out. Common problem with new fiber sealing washers. I'm assuming they are the fiber ones, as pretty much all the rebuild kits I've seen include the fiber washers... (IMG:style_emoticons/default/confused24.gif) [/quote I soaked it in oil for a few hours and re-installed it. It looks like that might have done the trick. Thanks for the tip. [/quote] Keep a close eye on it. watched a local teener burst into flames at the last autocross after it lost a plug from a carb. Needless to say it didnt help my opinion of carbs.... |
Elliot Cannon |
Aug 21 2016, 05:03 PM
I think I finally got something that would stop the leak. I bought very thin 1/2 inch mylar washers, opened them up to 9/16, squeezed one of them over the threads of the plug, installed it and so far no leaks. I'm pretty sure the mylar will hold up. I'm told mylar never deteriorates. Ever. (IMG:style_emoticons/default/biggrin.gif)
Eric_Shea |
Aug 21 2016, 05:13 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Also, for future work, get an extra 6 sided 19mm and shave it down so the mating surfaces are perfectly square. It helps you get some torque on that fitting without damaging it.
Elliot Cannon |
Aug 21 2016, 05:39 PM
Eric_Shea |
Aug 21 2016, 05:50 PM
I think so (IMG:style_emoticons/default/blink.gif)
Elliot Cannon |
Aug 21 2016, 08:22 PM
Yah, OK. I went out and looked at my 19mm socket and see exactly what you mean. As Jules said to Brad, "you a smart mofo"! |
Lo-Fi Version | Time is now: 26th April 2024 - 10:40 PM |
