Any thoughts on this? Apparently they believe new bearings can be improved, Re-grease new sealed dual-row bearing |
mskala |
Jul 29 2016, 02:35 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I saw this and what they are talking about is the type of wheel bearings used in
914 rear. Re-greasing new sealed bearings if racing with them When we buy FAG or SKF bearings for $40 to $80, are they cheaping out on the grease used within? |
Mark Henry |
Jul 29 2016, 04:55 PM
I wish I had thought about this as well, but they are already installed.
On a similar note I've read a few times that clutch release bearings are not serviceable, but I found them quite easy to press apart, clean, regrease with Swepco 101 and press back together. You do need a small press, but in a pinch you could do it with a vice. |
Lo-Fi Version | Time is now: 7th June 2024 - 04:24 PM |
