> body work question rear valence, can I fix this? Progress with boring pics
theleschyouknow
post Aug 3 2016, 07:35 PM
I've had my car for about two years first year -what I call the year of living dangerously
I drove it whenever the weather allowed including a 914 weekend in the talimena hills
after a brokenclutch cable clevis it's been wheels in the air for close to a year I've been cleaning the engine and trans and suspension arms and cv's/axles and shocks & springs and engine tin I can reach of 40+ years of grease and dirt -a bunch of it likely from the leaking cv's which I'm sure I'll ask about soon in another thread
so here's my question for this thread:
my rear valence has one 'big' dent in it and couple small wrinkles in the bottom 1/4" or so 'return' flange that defines the bottom edge
pics following
having never done any kind of body work before this seems fairly straight forward to repair
what are the minimal tools required?
what kind of results could reasonably be expected?
could I (easily)screw it up beyond repair?
thanks for any comments or suggestions
cjl
worn
post Aug 4 2016, 01:12 PM
-hammer, not claw, and something to hit against
-perfect if you skim a light film of bond over the end result. probably 1/16 in or so thick with no experience.
- I doubt it.
As you pound out the dent avoid squeezing it tight against the anvil. If you here a distinct click as the hammer hits it is striking the anvil through the metal. That stretches. So hit to move the dent and bend the metal back into shape. As long as you aren't pinching the metal you are probably shrinking or at least not ruining it. Read. Your's looks like mine did a couple months ago. Close to perfect now.
theleschyouknow   body work question rear valence   Aug 3 2016, 07:35 PM
barefoot   Take it off, put it in your kids sandbox and shape...   Aug 3 2016, 07:48 PM
steuspeed   I'm no expert, but I was able to pound out som...   Aug 3 2016, 08:16 PM
Mikey914   You can do it.   Aug 3 2016, 11:45 PM
porschetub   Find a block of hardwood shape it as you need and ...   Aug 4 2016, 12:44 AM
jacksun   how about using two 2x6's place wood clamps ...   Aug 4 2016, 04:46 AM
theleschyouknow   thanks for the encouragement and suggestions I wi...   Aug 4 2016, 11:16 AM
Jeffs9146   You could go dual exhaust!!!! :bee...   Aug 4 2016, 12:01 PM
theleschyouknow   You could go dual exhaust!!!! :be...   Aug 4 2016, 01:02 PM
malcolm2   $26 PROfessional tools from Harbor Freight mi...   Aug 4 2016, 12:18 PM
worn   having never done any kind of body work before thi...   Aug 4 2016, 01:12 PM
theleschyouknow   well a cheap set of harbor freight tools, a sand b...   Aug 7 2016, 10:57 AM
theleschyouknow   RE: body work question rear valence   Aug 7 2016, 11:00 AM
theleschyouknow   RE: body work question rear valence   Aug 7 2016, 11:01 AM
theleschyouknow   :beer2: cjl   Aug 7 2016, 11:06 AM
zambezi   Are you using a hammer and dolley or just the hamm...   Aug 8 2016, 11:01 AM
theleschyouknow   Are you using a hammer and dolley or just the ham...   Aug 8 2016, 11:48 AM
Darren C   Your doing real well cjl, Very good work! T...   Aug 8 2016, 12:36 PM
theleschyouknow   thanks Darren I was kinda hoping you would chime i...   Aug 8 2016, 05:18 PM
Darren C   I could use some of your weather. Its 8am here, w...   Aug 9 2016, 12:50 AM
porschetub   I could use some of your weather. Don't pl...   Aug 9 2016, 08:36 PM
theleschyouknow   thanks for the support Darren I'll split the d...   Aug 9 2016, 08:16 PM
theleschyouknow   thanks -tub it's getting there :beer2: cjl   Aug 9 2016, 09:37 PM
Darren C   "one question regarding the bottom return fla...   Aug 10 2016, 12:45 AM
theleschyouknow   here's a couple pics of what I'm talking a...   Aug 10 2016, 07:41 PM
theleschyouknow   and below is shot of one of the vertical brackets ...   Aug 10 2016, 07:49 PM
Darren C   Thanks, posting the pictures saves a 1000 words...   Aug 11 2016, 01:36 AM
theleschyouknow   thanks Darren, good advice & good explanation ...   Aug 11 2016, 06:03 PM
- Lo-Fi Version Time is now: 1st July 2025 - 03:00 AM
