| Garland |
Aug 6 2016, 02:26 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
This engine is for my Michigan Build, 2016 Build-Off Challenge. Needed to come to the "Garage" for some help.
Fresh rebuilt on start up, my first oil filter inflated, then leaked at the seal. Second try, filter massive leak blew the seal out. I have a flow probem. Looking for help. I must be building pressure, just won't leave the filter. |
| Garland |
Aug 7 2016, 11:56 AM
Me to, here it is!
Used a home made slide hammer, after taping the piston. Washed out and Cleaned up the passage , and going to replace the piston, spring and cap. ![]() ![]() ![]() ![]() ![]() |
Garland Oil filter bulge, Jiffy Pop NEW concern Aug 6 2016, 02:26 PM
Garland Filter off
Aug 6 2016, 02:37 PM
Mark Henry First thought is you have a seized oil control pis... Aug 6 2016, 02:57 PM
Garland Mark,
Thank you I have contacted the member I got... Aug 6 2016, 03:50 PM
stugray Something must be seriously wrong, and I dont know... Aug 6 2016, 04:23 PM
Mark Henry
Something must be seriously wrong, and I dont kno... Aug 6 2016, 04:27 PM
Mark Henry I'd look at the piston first, my bet is it... Aug 6 2016, 04:25 PM
Mark Henry dp Aug 6 2016, 04:26 PM
Mark Henry Was the filter and console on it when you got it?
... Aug 6 2016, 04:32 PM
Garland Here we go... Filter was with engine, no bugs :D ... Aug 6 2016, 04:41 PM
Drums66 .....Dirt daubers(in USA) :popcorn: :popcorn:
:... Aug 6 2016, 05:35 PM
r_towle Garland, please check your pm,s. Aug 6 2016, 08:05 PM
Garland Rich, check your E-mail.
Thanks,
John
Can't... Aug 7 2016, 07:50 AM
Mark Henry Big screwdriver, hold it at an angle and to one si... Aug 7 2016, 08:14 AM
rgalla9146 I'd go with a hand impact.
About a $20 ... Aug 7 2016, 08:47 AM
Garland :smash: :smash: :smash: not working! Aug 7 2016, 08:55 AM
Mark Henry
Harde... Aug 7 2016, 10:33 AM
Garland Impact seems a bit aggressive, but at this point a... Aug 7 2016, 09:43 AM
Garland It's moving, 1/4 turn so far. I had to cut two... Aug 7 2016, 10:48 AM
stugray
It's moving, 1/4 turn so far. I had to cut tw... Aug 7 2016, 11:21 AM
rgalla9146
It's moving, 1/4 turn so far. I had to cut t... Aug 7 2016, 11:45 AM
Mark Henry Wow that is one of the worst I've seen...??? ... Aug 7 2016, 11:28 AM
Garland
Wow that is one of the worst I've seen...??? ... Aug 7 2016, 12:24 PM
stugray
Me to, here it is!
Used a home made slide ha... Aug 7 2016, 12:15 PM
396
Me to, here it is!
Used a home made slide h... Aug 7 2016, 01:41 PM
stugray
Sorry to hear of your concerns...
Now that you kn... Aug 7 2016, 01:59 PM
Garland "I would go directly to tangerine racing, do ... Aug 7 2016, 12:30 PM
stugray
"I would go directly to tangerine racing, do... Aug 7 2016, 12:43 PM
Garland I think it will still work. I cleaned up the bore ... Aug 7 2016, 01:21 PM
stugray
I think it will still work. I cleaned up the bore... Aug 7 2016, 01:25 PM
pgollender What is the length of the spring supposed to be ? ... Aug 7 2016, 03:37 PM
Mark Henry
I had high oil pressure too on initial start-up ... Aug 7 2016, 04:18 PM
Garland Each start was 5 sec or less, started now, 3 times... Aug 7 2016, 08:50 PM
stugray What does the oil pressure read at the pressure se... Aug 7 2016, 10:06 PM
396 Im a little confused. Is this a "used" e... Aug 8 2016, 09:09 AM
rgalla9146
Im a little confused. Is this a "used" ... Aug 8 2016, 02:21 PM
porschetub
Im a little confused. Is this a "used" ... Aug 9 2016, 01:10 AM
Garland This was purchased 10 years ago as a rebuilt motor... Aug 8 2016, 09:28 AM
Garland It is a,
1.7 balanced, 260 x 396 cam .006
96mm B... Aug 8 2016, 08:53 PM
Mark Henry I love the DCNF, infact I have a set of Gene Berg ... Aug 9 2016, 08:24 AM
Garland Mark, I am aware of that but I have read a number ... Aug 9 2016, 11:58 AM
Mark Henry
Mark, I am aware of that but I have read a number... Aug 9 2016, 01:23 PM
stugray
Mark, I am aware of that but I have read a numbe... Aug 9 2016, 02:40 PM
Garland Here's is the track I was following, and it di... Aug 9 2016, 08:45 PM
Mark Henry
But this idea I like, have to work on that, a b... Aug 10 2016, 11:07 AM
Garland Mark, I like your idea I do not plan on trying to ... Aug 10 2016, 01:49 PM
Garland Everything buttoned up and ran for 30 minutes at a... Aug 13 2016, 10:12 AM
stugray
Everything buttoned up and ran for 30 minutes at ... Aug 13 2016, 12:47 PM
porschetub
Everything buttoned up and ran for 30 minutes at ... Aug 13 2016, 11:30 PM
Mark Henry
My carbs are different however they are off a E... Sep 8 2016, 12:56 PM
Garland Engines running, timed like stock. The only concer... Sep 7 2016, 12:40 PM
Garland Valve clearance is ok. I back down the timing a bi... Sep 7 2016, 08:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 04:28 PM |
