914 Brake Pressure Swith - The One On The Master Cyliner, Where Can I Purchase A Single Pole One? |
NoEcm |
Aug 7 2016, 05:23 PM
Member Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 |
I have a leaking pressure switch on the master cylinder and I need to purchase a single pole one for a '75.
Is this part available separately? |
JeffBowlsby |
Aug 7 2016, 05:46 PM
914 Wiring Harnesses Group: Members Posts: 8,549 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The single pole switch grounds through the switch case, where the two pole requires a separate ground wire to the chassis if you need to use it.
Lo-Fi Version | Time is now: 17th June 2024 - 12:57 AM |
