> Oil filter bulge, Jiffy Pop NEW concern, 1 cyl intermittently pre-detonates help! Michigan Build, 2016 Build-Off
Garland
post Aug 6 2016, 02:26 PM
Restoration Fanatic
This engine is for my Michigan Build, 2016 Build-Off Challenge. Needed to come to the "Garage" for some help.
Fresh rebuilt on start up, my first oil filter inflated, then leaked at the seal. Second try, filter massive leak blew the seal out. I have a flow probem. Looking for help. I must be building pressure, just won't leave the filter.
Garland
post Aug 7 2016, 08:50 PM
Restoration Fanatic
Each start was 5 sec or less, started now, 3 times. 3 rd times, the charm.
Back together and 3 rd start, no leeks pressures holding, so far.
I did add oil to the cylinders, a few times over the years. This could be that residue.
I'll know more after I crank it, and change the oil. Then may start breakin.
Garland   Oil filter bulge, Jiffy Pop NEW concern   Aug 6 2016, 02:26 PM
Garland   Filter off   Aug 6 2016, 02:37 PM
Mark Henry   First thought is you have a seized oil control pis...   Aug 6 2016, 02:57 PM
Garland   Mark, Thank you I have contacted the member I got...   Aug 6 2016, 03:50 PM
stugray   Something must be seriously wrong, and I dont know...   Aug 6 2016, 04:23 PM
Mark Henry   Something must be seriously wrong, and I dont kno...   Aug 6 2016, 04:27 PM
Mark Henry   I'd look at the piston first, my bet is it...   Aug 6 2016, 04:25 PM
Mark Henry   dp   Aug 6 2016, 04:26 PM
Mark Henry   Was the filter and console on it when you got it? ...   Aug 6 2016, 04:32 PM
Garland   Here we go... Filter was with engine, no bugs :D ...   Aug 6 2016, 04:41 PM
Drums66   .....Dirt daubers(in USA) :popcorn: :popcorn: :...   Aug 6 2016, 05:35 PM
r_towle   Garland, please check your pm,s.   Aug 6 2016, 08:05 PM
Garland   Rich, check your E-mail. Thanks, John Can't...   Aug 7 2016, 07:50 AM
Mark Henry   Big screwdriver, hold it at an angle and to one si...   Aug 7 2016, 08:14 AM
rgalla9146   I'd go with a hand impact. About a $20 ...   Aug 7 2016, 08:47 AM
Garland   :smash: :smash: :smash: not working!   Aug 7 2016, 08:55 AM
Mark Henry   :smash: :smash: :smash: not working! Harde...   Aug 7 2016, 10:33 AM
Garland   Impact seems a bit aggressive, but at this point a...   Aug 7 2016, 09:43 AM
Garland   It's moving, 1/4 turn so far. I had to cut two...   Aug 7 2016, 10:48 AM
stugray   It's moving, 1/4 turn so far. I had to cut tw...   Aug 7 2016, 11:21 AM
rgalla9146   It's moving, 1/4 turn so far. I had to cut t...   Aug 7 2016, 11:45 AM
Mark Henry   Wow that is one of the worst I've seen...??? ...   Aug 7 2016, 11:28 AM
Garland   Wow that is one of the worst I've seen...??? ...   Aug 7 2016, 12:24 PM
Garland   Me to, here it is! Used a home made slide ham...   Aug 7 2016, 11:56 AM
stugray   Me to, here it is! Used a home made slide ha...   Aug 7 2016, 12:15 PM
396   Me to, here it is! Used a home made slide h...   Aug 7 2016, 01:41 PM
stugray   Sorry to hear of your concerns... Now that you kn...   Aug 7 2016, 01:59 PM
Garland   "I would go directly to tangerine racing, do ...   Aug 7 2016, 12:30 PM
stugray   "I would go directly to tangerine racing, do...   Aug 7 2016, 12:43 PM
Garland   I think it will still work. I cleaned up the bore ...   Aug 7 2016, 01:21 PM
stugray   I think it will still work. I cleaned up the bore...   Aug 7 2016, 01:25 PM
pgollender   What is the length of the spring supposed to be ? ...   Aug 7 2016, 03:37 PM
Mark Henry   I had high oil pressure too on initial start-up ...   Aug 7 2016, 04:18 PM
Garland   Each start was 5 sec or less, started now, 3 times...   Aug 7 2016, 08:50 PM
stugray   What does the oil pressure read at the pressure se...   Aug 7 2016, 10:06 PM
396   Im a little confused. Is this a "used" e...   Aug 8 2016, 09:09 AM
rgalla9146   Im a little confused. Is this a "used" ...   Aug 8 2016, 02:21 PM
porschetub   Im a little confused. Is this a "used" ...   Aug 9 2016, 01:10 AM
Garland   This was purchased 10 years ago as a rebuilt motor...   Aug 8 2016, 09:28 AM
Garland   It is a, 1.7 balanced, 260 x 396 cam .006 96mm B...   Aug 8 2016, 08:53 PM
Mark Henry   I love the DCNF, infact I have a set of Gene Berg ...   Aug 9 2016, 08:24 AM
Garland   Mark, I am aware of that but I have read a number ...   Aug 9 2016, 11:58 AM
Mark Henry   Mark, I am aware of that but I have read a number...   Aug 9 2016, 01:23 PM
stugray   Mark, I am aware of that but I have read a numbe...   Aug 9 2016, 02:40 PM
Garland   Here's is the track I was following, and it di...   Aug 9 2016, 08:45 PM
Mark Henry   But this idea I like, have to work on that, a b...   Aug 10 2016, 11:07 AM
Garland   Mark, I like your idea I do not plan on trying to ...   Aug 10 2016, 01:49 PM
Garland   Everything buttoned up and ran for 30 minutes at a...   Aug 13 2016, 10:12 AM
stugray   Everything buttoned up and ran for 30 minutes at ...   Aug 13 2016, 12:47 PM
porschetub   Everything buttoned up and ran for 30 minutes at ...   Aug 13 2016, 11:30 PM
Mark Henry   My carbs are different however they are off a E...   Sep 8 2016, 12:56 PM
Garland   Engines running, timed like stock. The only concer...   Sep 7 2016, 12:40 PM
Garland   Valve clearance is ok. I back down the timing a bi...   Sep 7 2016, 08:19 PM
- Lo-Fi Version Time is now: 22nd November 2026 - 04:28 PM
