jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I have an old 15" Walked turner drill press that dates back to the 40's. It's a wonderful beast of a cast iron machine, but the pulley that goes on the quill is messed up. The bronze splinned bushing inside was slipping. But I am a smart guy, and taking inspiration from the method we use to put the cam gear on a type 4 crank, I heated it up on a hot plate thinking I could then drive the bushing in tighter.
I ended up melting the largest diameter step off the pulley. (IMG:style_emoticons/default/headbang.gif) I have not been able to source a replacement. Got to thinking, since I am trying to run at a lower speed, why not just get a motor controller and turn down the speed? Any one know if this would work, and a good place for a speed control? |
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
It's called a VFD. . Variable frequency drive
DavidSweden |
Member ![]() ![]() Group: Members Posts: 481 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
It's called a VFD. . Variable frequency drive the variable speed drive (VSD) should work fine and they are cheap. A single phase VSD can run a 3 phase motor but you need to be sure what your buying . You will need to set it up but its not brain surgery. you can usually use a variable resistor to control the speed. I recommend installing an emergency stop button. Good luck |
Lo-Fi Version | Time is now: 20th July 2025 - 07:30 PM |
