jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I have an old 15" Walked turner drill press that dates back to the 40's. It's a wonderful beast of a cast iron machine, but the pulley that goes on the quill is messed up. The bronze splinned bushing inside was slipping. But I am a smart guy, and taking inspiration from the method we use to put the cam gear on a type 4 crank, I heated it up on a hot plate thinking I could then drive the bushing in tighter.
I ended up melting the largest diameter step off the pulley. (IMG:style_emoticons/default/headbang.gif) I have not been able to source a replacement. Got to thinking, since I am trying to run at a lower speed, why not just get a motor controller and turn down the speed? Any one know if this would work, and a good place for a speed control? |
MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
Have you put a WTB ad on OWWM.com? If you haven't checked out that site yet, you should. It's to old tools, as this site is to 914s..
jeffdon |
MrKona |
Have you put a WTB ad on OWWM.com? If you haven't checked out that site yet, you should. It's to old tools, as this site is to 914s.. Awesome, thanks. Will check it out. Also, check out the classifieds on OWWM.org. (Note the .org versus .com). The two sites are affiliated... how I'm not sure. I think you need to register to access the classified ads. Great sites. |
Lo-Fi Version | Time is now: 20th July 2025 - 07:23 PM |
