jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
I have an old 15" Walked turner drill press that dates back to the 40's. It's a wonderful beast of a cast iron machine, but the pulley that goes on the quill is messed up. The bronze splinned bushing inside was slipping. But I am a smart guy, and taking inspiration from the method we use to put the cam gear on a type 4 crank, I heated it up on a hot plate thinking I could then drive the bushing in tighter.
I ended up melting the largest diameter step off the pulley. (IMG:style_emoticons/default/headbang.gif) I have not been able to source a replacement. Got to thinking, since I am trying to run at a lower speed, why not just get a motor controller and turn down the speed? Any one know if this would work, and a good place for a speed control? |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Post pictures of damage. Maybe it's something we can fix at my place.
You can also convert to a DC motor with a variable power supply....which I have 2 or 3 setups I've taken off of free/salvaged threadmills. Free for the asking if want to pick one up. I think 1 or 1.5hp motors. Check out Surplus Center . Com, I bought my pulleys for my Bridgeport mill from there. |
jeffdon |
Post pictures of damage. Maybe it's something we can fix at my place. You can also convert to a DC motor with a variable power supply....which I have 2 or 3 setups I've taken off of free/salvaged threadmills. Free for the asking if want to pick one up. I want to 1 or 1.5hp motors. Check out Surplus Center . Com, I bought my pulleys for my Bridgeport mill from there. Its pretty bad. Anyone know if the splined bushing inside just presses out? ![]() |
Lo-Fi Version | Time is now: 20th July 2025 - 07:03 PM |
