> installing gauges, need help/advice wiring oil temp and pressure gauges
914 RZ-1
post Jul 15 2016, 02:56 PM
Porsche Padawan
I got oil pressure and oil temp gauges. The instructions are generic and I'd like some specifics about how to install them on my 1.7L '72. Sorry if these seem obvious; I've never done this before.
1. Standard ground or floating ground? I'm leaning toward floating because it looks obvious how to attach the ground. On the standard ground, how do I attach the gnd wires?
2. What do I attach the wire from the gauge light socket to the light switch to? The headlight switch? Which connector?
3. Which fuse do I use for power? #9?
4. I figure I will just attach grounds to a screw on the body, either an existing one or a new one.
5. What is the "switched +12v" light shown in the instructions? The dummy light?
6. Does the oil pressure sensor get installed where the current oil pressure switch is by the distributor? Doesn't appear to be any room, but I'll need to move some hoses, etc out of the way.
7. Where does the oil temp sensor go? The instructions state that it can replace the drain plug. Is this correct?
8. Where is the best route for the wires? I was thinking thru the middle along where the other wiring harness is located. What should I do with them in the engine compartment: zip tie them to other wires, or let them hang free, or what?
If anyone has done this and has pictures or a more detailed description, I'd appreciate it.
Mike D.
post Aug 9 2016, 01:18 PM
OK, It runs now, and pretty good too!
Jeff, I have a extra brake hose you can use. I know it fits the sender, but you'll need to find a male to male fitting for the case to hose. Maybe Metric Specialties?
914 RZ-1
post Aug 9 2016, 01:43 PM
Porsche Padawan
QUOTE(Mike D. @ Aug 9 2016, 12:18 PM) *
Thanks, Mike, but I got the parts at Bouquet Auto. I just decided to get the NPT fittings. They are really close. The people there said it would work, just put them together finger tight with Teflon tape then give them a small, 1/8 of a turn to seat them.
Metric Specialties didn't have anything. I called or looked at: McMaster-Carr, Graingers, Fastenal, Swagelok, McFadden-Dale, Empi, cip1, and a few other places on the internet. I even called a plumbing supply place.
I emailed Auto Atlanta and asked about the threads on the kit they have. They want $64. Still haven't heard anything.
What did you use from the case to the hose?
914 RZ-1   installing gauges   Jul 15 2016, 02:56 PM
TeenerTech   where are you mounting the gauges? if your mountin...   Jul 16 2016, 10:55 AM
914 RZ-1   where are you mounting the gauges? if your mounti...   Aug 6 2016, 05:52 PM
TeenerTech   You can get the hose from Auto Atlanta and the wir...   Aug 6 2016, 06:34 PM
914 RZ-1   You can get the hose from Auto Atlanta and the wi...   Aug 9 2016, 11:23 AM
914 RZ-1   I'm mounting the gauges under the dash with a ...   Jul 31 2016, 04:09 PM
GeorgeRud   Unless you use the ashtray, this makes a convenien...   Jul 31 2016, 07:39 PM
914 RZ-1   Unless you use the ashtray, this makes a convenie...   Aug 6 2016, 05:50 PM
914 RZ-1   Here's what I think I will do: WIRING 1. 3 co...   Aug 6 2016, 05:48 PM
Mike D.   Jeff, I have a extra brake hose you can use. I kno...   Aug 9 2016, 01:18 PM
914 RZ-1   Jeff, I have a extra brake hose you can use. I kn...   Aug 9 2016, 01:43 PM
Carl456   Following along quietly.... I have a vacuum guage ...   Aug 9 2016, 04:38 PM
914 RZ-1   Following along quietly.... I have a vacuum guage...   Aug 20 2016, 02:33 PM
Harpo   I threaded an 1/8 NPT fitting down in to my block....   Aug 20 2016, 06:30 PM
N_Jay   I threaded an 1/8 NPT fitting down in to my block...   Sep 16 2016, 07:08 AM
cuddyk   I bought this kit. Has everything you need, includ...   Aug 20 2016, 06:50 PM
914 RZ-1   So I got the gauges installed. I think the oil tem...   Sep 15 2016, 11:12 PM
Mikey914   Just finished the wiring harness for the appearanc...   Sep 16 2016, 12:16 AM
914 RZ-1   It seems the oil temp gauge works. I drove the car...   Sep 16 2016, 08:34 PM
914 RZ-1   One other question: how do I pull out the bulbs on...   Sep 16 2016, 08:41 PM
advman89   One other question: how do I pull out the bulbs o...   Nov 17 2021, 02:54 PM
Dave_Darling   Looks like the black part should pull out the back...   Sep 16 2016, 09:57 PM
914 RZ-1   Looks like the black part should pull out the bac...   Sep 18 2016, 10:58 AM
zambezi   I'll add to Dave that if you are using the cor...   Sep 17 2016, 10:28 AM
914 RZ-1   I got the gauges to work! I'm getting rea...   Sep 18 2016, 10:54 AM
advman89   I have everything operating..except the pressure g...   May 17 2022, 08:53 PM
advman89   I'm starting my own gauge journey today. He...   Feb 12 2022, 08:25 AM
emerygt350   Just be careful you don't end up with GAS. Ga...   Feb 12 2022, 01:26 PM
advman89   HA! I'm trying to keep it classy!   Feb 12 2022, 06:33 PM
advman89   Tackling the oil temp sensor. 1971 with a 1975 2.0...   Feb 13 2022, 11:31 AM
930cabman   Are you using the factory oil pressure sender?   May 18 2022, 01:51 PM
advman89   No. I'm using a VDO dual pole sending unit...i...   May 18 2022, 04:07 PM
FlacaProductions   The dual pole senders trip the oil light “earlyâ...   May 18 2022, 05:26 PM
advman89   Good to know on tripping the light early. ...now...   May 19 2022, 11:43 AM
Retroracer   On the oil pressure gauge pinning issue, suggest t...   May 19 2022, 02:04 PM
- Lo-Fi Version Time is now: 1st August 2025 - 08:43 AM
